Текущее время: 13 май 2024, 03:25
surn32
Заголовок сообщения: gv-n208sgaming-8gc no 1.8v Добавлено: 17 май 2023, 18:48 |
Зарегистрирован: 29 янв 2022, 21:37 Наличности на руках: 37.03
Сообщения: 7 Откуда: Cádiz
Hi everyone, I have a Gigabyte RTX 2080 Super graphics card, model gv-n208sgaming-8gc rev 2.0. The issue I'm facing is that I don't have the 1.8V voltage. I have checked similar schematics (from a Gigabyte RTX 2080) and found that the enable signal in U11, responsible for the 1.8V, is missing. Using a boardview of a Gigabyte RTX 2080 Super OC, I discovered an AND gate that is missing the PS_VMON_PGOOD voltage, which is provided by U37 (INA3221AIRGVR), but that component is not present on my graphics card. I would appreciate any hints on where I could look for a solution. Thank you very much. I have attached photos of the measurements. P.S.: The logic gate is functioning properly, and the resistors are not open; they have been removed, replaced, and tested.
