Текущее время: 23 июн 2024, 23:51
madking
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 11 сен 2023, 20:22 |
![Продвинутый форумчанин Продвинутый форумчанин](./images/ranks/gemstone_ranks/blue/blue5.gif) |
Зарегистрирован: 03 ноя 2017, 01:24 Наличности на руках: 5,011.04 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 4005 Откуда: Budapest
Uzair Farooq писал(а): Hi I have gigabyte rtx 3060 ti vision oc rev 2 lHR maybe The problem is already described in title that the card has memory errors on B1 chip and C0 on mats test but even after replacing them 2 times the errors are still there. The card is detected and can give alot of lines display output. GPU reball
![](images/spacer.gif) |
jeffersonsilva998
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 11 сен 2023, 21:02 |
![Аватара пользователя](./download/file.php?avatar=128298_1647045058.jpg) |
Зарегистрирован: 12 янв 2022, 23:43 Наличности на руках: 18.13 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 47 Откуда: brazil
The RTX 3060 Ti has some peculiarities, and there are different PCBs for this card. In this confusion, some of the PCBs have swapped data contacts in channels B1 and C0. So, there are BIOS versions for these two types of PCBs. Try different BIOS versions, and you should find one that corrects these errors in channels B1 and C0. However, before doing that, it would be interesting to know the brand of the memory and the model you are dealing with. Please send a photo if possible. madking писал(а): GPU reball At the very least, it would be crazy to reball the GPU before any further signs of a soldering problem. It could only cause more problems on the board.
Uzair Farooq
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 13 сен 2023, 14:54 |
![Я тут случайно Я тут случайно](./images/ranks/gemstone_ranks/grey/grey1.gif) |
Зарегистрирован: 16 май 2023, 09:16 Наличности на руках: 21.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 9 Откуда: Rawal town kamalabad near tayeba masjid rawalpindi, Pakistan
jeffersonsilva998 писал(а): The RTX 3060 Ti has some peculiarities, and there are different PCBs for this card. In this confusion, some of the PCBs have swapped data contacts in channels B1 and C0. So, there are BIOS versions for these two types of PCBs. Try different BIOS versions, and you should find one that corrects these errors in channels B1 and C0.
However, before doing that, it would be interesting to know the brand of the memory and the model you are dealing with. Please send a photo if possible. Chek
Uzair Farooq
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 15 сен 2023, 19:15 |
Can you tell what to do?
Uzair Farooq
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 19 сен 2023, 01:38 |
jeffersonsilva998 писал(а): In the documentation of some graphics cards, you can find the necessary information to make such changes. Okay i wik try your method i already tried gigabyte vision and gaming x bios but it was not successful. But i feel the errors reducing by changing to different bios,i mean memory errors in tserver.. Also problem that I cannot view any link or file in the form. I don't know what to do to start viewing those files
pLeXz
Заголовок сообщения: Re: Gigabyte 3060 ti vision oc B1 C0 errors ![Сообщение Сообщение](./styles/AeroBlack/imageset/icon_post_target.gif) Добавлено: 19 сен 2023, 15:06 |
Зарегистрирован: 16 июн 2023, 23:08 Наличности на руках: 29.00 ![](./styles/AeroBlack/theme/images/money.png)
Сообщения: 22 Откуда: 2la
Uzair Farooq писал(а): But i feel the errors reducing by changing to different bios If replace to 100% working chip is not help - take off GPU and chip with errors and check connection between data lines from memory to gpu, if all is fine - try to reball GPU, if does not help, i guess GPU is not work properly.
