msi 1660s ventus - crash https://vlab.su/viewtopic.php?f=48&t=137308 |
deathdealer9982 [ 26 сен 2023, 12:44 ] | |
Заголовок сообщения: | msi 1660s ventus - crash |
When I run the benchmark in any mode, the image disappears and the fan is max speed. Mods ok with -test 93, 94,118.... ( dramclk_percent 100) . But when i use - test 178 ,the screen displays test mode ( about 4s) and then the image disappears , fan is maxspeed. Help me check where is the problem. Thank you |
allas [ 08 окт 2023, 11:57 ] | |
Заголовок сообщения: | Re: msi 1660s ventus - crash |
Try reball gpu.I have the same problem with RTX 2070 and reball help. |
