Текущее время: 21 ноя 2024, 22:36
 Заголовок сообщения: KVA2 RTX 2060 Super 8GB - Artifacts only without load
СообщениеДобавлено: 06 фев 2024, 08:57
Hello (sorry for my bad English),
I have a strange problem with my KVA2 RTX 2060 Super. As soon as Windows 11 is loaded, artifacts appear. Now the crazy thing: When I start Furmark the artifacts are gone and Furmark runs great without crashing. Mats test shows me no errors (PASS). Drivers can also be loaded without any problems.
Voltages and resistances are normally, no shorts found.
Mods shows me the following error:
Failure(s) :
MODS start: Thu Feb 1 19:16:00 2024
Command Line : gputest.js -oqa -old_gold -test 94 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -fan_speed 70 -matsinfo
CPU
Foundry : AuthenticAMD
Name : AMD Ryzen 5 2600 Six-Core Processor
Family : 15
Model : 8
Stepping : 2
Version
MODS : 400.281
OperatingSystem: Linux (x86_64)
Kernel : 4.17.4-gentoo
KernelDriver : 3.87
SBIOS Version : 4901
SBIOS Date : 07/25/2022
HostName : tinylinux
GPU 0 [08:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x08, 0x00, 0x00
GPU DID : 0x1f06
PDI : 0x33d91aab89d9290c
Raw ECID : 0x014045c00000007028442191
Raw ECID (GHS) : 0x1647028442000000017020280
ECID : PS2X48-23_x04_y10
Device Id : TU106
Revision : a1
NV Base : 0xfb000000
FB Base : 0xd0000000
IRQ : 59
WARNING: GPU 0 [08:00.0] PCIE speed capability (8000Gbps) higher than down stream port link speed (2500Gbps)
ERROR: SMBus controller Not found
Setting Fan 1 of GPU 0 [08:00.0] to 70%
Foundry : TSMC
Subsystem VID : 0x10de
Subsystem DID : 0x13a3
Board ID : 0x0160
Chip SKU : 410-0
Project : G160-0062
Fuse File Fmt : JSON
Display : 0x00000100 (id)
SBIOS Init : Primary
Native Mode : 1920x1080
Memory Size : 8192 MB
FB Vendor : Micron
RAM Protocol : GDDR6
RAM Config : 1
ROM Version : 90.06.44.80.5d
ROM Type : Partner Production
ROM OEM Vendor : NVIDIA
ROM Partner : galaxy
ROM Project ID : 107293galaxy
ROM Timestamp : 2019-6-12 17:09:31
ROM Expiration : 2019-12-9 17:09:31
ROM GUID : 2D6AC2F846E34A8DBF8F581AA44D2AD8
PPC Pri/Sec FW : Unknown
PPC Driver Ver : Unknown
PState (mode) : 8 5 3 2 [0]
PState Version : 3.5
EDC : Disabled
GPC Clock : 1890.0/1885.3 MHz NAFLL
DRAM Clock : 7001.0/7014.0 MHz DEFAULT
Host Clock : 1350.0/1349.7 MHz NAFLL
XBar Clock : 1800.0/1800.1 MHz NAFLL
Sys Clock : 1890.0/1888.4 MHz NAFLL
Power Clock : 540.0/540.5 MHz DEFAULT
NVDec Clock : 1755.0/1746.2 MHz NAFLL
Display Clock : 1330.0/1329.0 MHz DEFAULT
NVVDD : 1062 mV
GPC Mask : 0x07 (3 GPCs)
TPC Mask : [3f 3f 3e] (17 TPCs)
FB Mask : 0x0f (4 FB Partitions)
ROP/L2 Mask : [3 3 3 3] (8 ROP/L2s)
PES Mask : [7 7 7] (9 PESes)
FBIO Mask : 0x0f (4 FBIO Partitions)
FBIO Shift Mask: 0x00
XP Mask : 0x03 (2 3gio Pads)
Nvdec Mask : 0x07 (3 engines)
Nvenc Mask : 0x01 (1 engine)
Gpu Temp : 48 deg C
PEX Rx Lanes : 0x00ff
PEX Tx Lanes : 0x00ff
PEX Det. Lanes : 0x00ff
PEX Width, ASLM: 8 lanes, Not Supported
PEX Link Speed : 8.0 Gbit/s
PEX BandWidth : 64.0 Gbit/s
ASPM, ASPM-CYA : (L0s/L1, Disabled)
ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
LTR : Disabled
Chipset
VID : 1022 (AMD)
Chipset DID : 1450 (Unknown)
Chipset ASPM : L1
ASPM L1 SS : Disabled
RM Version : rel/gpu_drv/r400/r400_00-823
resumehandler.js: 1
gputest.js : 81
oqa.spc : 3
boards.js : 3
Running test(s) on GPU 0 [08:00.0] (DID: 0x1f06)
Enter SetPState (test 0)
Switched to PState 0 (0.max). Pcie Speed=8000, x8
Speed = 8.0Gb/s, expected 8.0Gb/s
UpStreamWidth = 8, expected 16
Error 020000000143 : Global.SanityCheckLink PCI Express bus error
Exit 020000000143 : SetPState (test 0) PCI Express bus error
Error!
Error 020000000143 : SetPState (test 0) PCI Express bus error
Enter NewWfMats (test 94)
Exit 000000000000 : NewWfMats (test 94) ok
GPU tests completed.
Failure(s) :
LOOP TEST CODE MESSAGE
1 SetPState 020000000143 PCI Express bus error
Error Code = 020000000143 (PCI Express bus error)
MODS end : Thu Feb 1 19:16:26 2024 [26.301 seconds (00:00:26.301 h:m:s)]
What could be the problem?
Many thanks
 Заголовок сообщения: Re: KVA2 RTX 2060 Super 8GB - Artifacts only without load
СообщениеДобавлено: 06 фев 2024, 09:19
PEX Width 8 lanes
СообщениеДобавлено: 06 фев 2024, 11:33
Many thanks for the answer. I'm relatively new to repairing graphics cards. What do you mean exactly? What should I take a closer look at? I haven't had a problem like that before
СообщениеДобавлено: 06 фев 2024, 12:23
Try overclocking test, then check the power supply to see if there are waveforms and see if the power can run up
СообщениеДобавлено: 06 фев 2024, 15:07
Yesterday I tested an rtx 3070 on my test bench with no problems. Power supply should work or does every GPU behave differently? As soon as the memory clock and GPU clock increases, the artifacts (squares) disappear. I tested the dramclk_percent 120 in mods and I get a few small errors, but not on every bank (pci test disabled)
В этой теме нет новых непрочитанных сообщений. RTX 2060 crash on load / bad voltage regulation - сбой при нагрузке/плохая регулировка напряжения
cxav
1358
17 дек 2022, 22:55
cxav Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2060 Super TURBO 8GB
bobbyD
25 апр 2021, 11:11
bobbyD Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. chieftec cft-850-14c sudden shutdown with or without load.
montarbo
17
3323
04 июн 2019, 14:31
mia Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Gigabyte 2060 Super/2060/1660Ti MODS
madking
10
2466
05 фев 2023, 07:07
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Satellite L350 PSLD0E (6050A2170201-MB-A03) run only without charger
в форуме Toshiba
habibou11
31 дек 2015, 14:48
DreamCatcher Перейти к последнему сообщению
Сейчас этот форум просматривают: madking, wid0wmak3r, Yandex [BOT] и гости: 47
