https://vlab.su/
asus rtx 3070 tuf convert to 3060ti
https://vlab.su/viewtopic.php?f=48&t=142115
Страница 1 из 1
huehu3gg [ 11 май 2024, 01:46 ]
Заголовок сообщения:  asus rtx 3070 tuf convert to 3060ti
Hi! i try to convert the Tuf 3070 (dead chip) to 3060ti (lhr) ! the thing is when i try to run mods say "NVRM Vbios invalid o reject"
of course i flash the bios with the 3060ti LHR v1 . i check all kind of strap i found... nothing change. and i try 2 3060ti chips.
the other 3060ti chip i put in a Palit 3060ti, and works well.
any ideas??
i know the msi v390 (gaming trio, ventus 3070 etc ) pcb and v397 (common 3060ti) pcb are not compatible because some data lines in B1 and C0 are diferent.
well the Asus 3070 tuf pcb is same config as the V390 , in terms of memory data lines.
any suggestion ?
edit: i try diferent bios chip.
http://www.phpbb.com/
