Текущее время: 21 ноя 2026, 04:27
 Заголовок сообщения: Nvidia Zotac 3070 LHR crashes while running mods on it
СообщениеДобавлено: 01 мар 2026, 22:16
Hello everyone,
I have Nvidia Zotac RTX 3070 Twin Edge OC and recently I've modded it to 16gb of vram using k4zaf325bm-hc16 chips. The card posts an image and also gives PASS on mats, but when I tried to install drivers, it crashes and gives black screen while the fans starts spinning at 100%.
I tried running mods 455.195.2 on it but it crashes.
Here is the log:
MODS arguments :
MODS start: Sat Feb 28 17:53:19 2026
Command Line : gputest.js -notest
CPU
Arch : x86_64
Name : Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
Cores : 12
Version
MODS : 455.195
System
OperatingSystem: Linux (x86_64)
Kernel : 5.9.1-gentoo-x86_64
KernelDriver : 4.00
SBIOS Version : P4.40
SBIOS Date : 07/30/2021
HostName : tinylinux
Available RAM : 15292/15718 MB (Free/Size)
Sys-uuid :
HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2488
PDI : 0xa06c8c131685bbdf
Raw ECID : 0x009ff3000000005db6e051c4
Raw ECID (GHS) : 0x4705db6e0500000000cff8100
ECID : SAMSUNG-SNRRWK-12_x-1_y4
Device Id : GA104
Revision : a1
Sub Revision : 1
NV Base : 0xde000000
FB Base : 0xc0000000
IRQ : 16
ERROR: ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[ ] NVRM: Unable to read VBIOS temperature limits.
[ ] NVRM: PMC_ENABLE for MC_ENGINE_IDX: 4 doesnt exist on current chip. Fix the caller.
[ ] NVRM: PMU_NOT_READY: Using Clocks 2.x to read pwrclk clock domain 19.
[ ] NVRM: OBJPMU Async: !Bootloader starting!
[ ] NVRM: OBJPMU Async: Bootloader base: 0x60600003FB8DA000
[ ] NVRM: OBJPMU Async: Booting...
[ ] NVRM: OBJPMU Async: Initializing PMU application
[ ] NVRM: OBJPMU Async: initPmuApp
[ ] NVRM: ringmaster interrupt GBL_WRITE_ERROR_FBP 0x0000000f!
[ ] NVRM: FBP(0) ringstation details : addr=0x0017e2b0 wrdata=0xe3010eff info=0xe3010eff code=0xbadf510c!
[ ] NVRM: FBP(0) ringstation details : subid=0x00000023 priv_level=0x00000000 priv_master=0x0000003f!
[ ] NVRM: FBP(1) ringstation details : addr=0x0017e2b0 wrdata=0xe3010eff info=0xe3010eff code=0xbadf510c!
[ ] NVRM: FBP(1) ringstation details : subid=0x00000023 priv_level=0x00000000 priv_master=0x0000003f!
[ ] NVRM: FBP(2) ringstation details : addr=0x0017e2b0 wrdata=0xe3010eff info=0xe3010eff code=0xbadf510c!
[ ] NVRM: FBP(2) ringstation details : subid=0x00000023 priv_level=0x00000000 priv_master=0x0000003f!
[ ] NVRM: FBP(3) ringstation details : addr=0x0017e2b0 wrdata=0xe3010eff info=0xe3010eff code=0xbadf510c!
[ ] NVRM: FBP(3) ringstation details : subid=0x00000023 priv_level=0x00000000 priv_master=0x0000003f!
[ ] NVRM: ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001!
[ ] NVRM: SYS(0) ringstation details : addr=0x00088050 wrdata=0x00000000 info=0x18408207 code=0xbadf5108!
[ ] NVRM: SYS(0) ringstation details : subid=0x00000018 priv_level=0x00000000 priv_master=0x00000007!
[ ] NVRM: FBP(0) ringstation error code: error = 0xbadf510c error code Unknown PRI_ERROR_CODE!
[ ] NVRM: FBP(1) ringstation error code: error = 0xbadf510c error code Unknown PRI_ERROR_CODE!
[ ] NVRM: FBP(2) ringstation error code: error = 0xbadf510c error code Unknown PRI_ERROR_CODE!
[ ] NVRM: FBP(3) ringstation error code: error = 0xbadf510c error code Unknown PRI_ERROR_CODE!
[ ] NVRM: ringmaster interrupt GBL_WRITE_ERROR_SYSC 0x00000001!
[ ] NVRM: SYSC(0) ringstation details : addr=0x0000a0b4 wrdata=0x00000000 info=0x1940822f code=0x00000000!
[ ] NVRM: SYSC(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x0000002f!
[ ] NVRM: BBX failed to start recording, status=0x56
[ ] NVRM: InfoROM does not have a valid ECC object!
[ ] NVRM: unable to query current ECC status (0x56)
[ ] NVRM: engHwIdMask for PMU-ELCG operations is empty
[ ] NVRM: Unable to cache ECC counts, status: 56
[ ] Warning: MSI for device 0000:01:00.0 not serviced
[ ] NVRM: SYS(0) ringstation details : addr=0x00127048 wrdata=0x00000000 info=0x18408326 code=0xbadf2026!
[ ] NVRM: SYS(0) ringstation details : subid=0x00000018 priv_level=0x00000000 priv_master=0x00000026!
[ ] NVRM: OBJPMU Async: Timed out waiting on DMA completion!
[ ] NVRM: OBJPMU Async: **** RTOS HAS CRASHED ****
[ ] NVRM: OBJPMU Async: OS: 30063123
[ ] NVRM: OBJPMU Async: Current task/ctx: 0x200030a8, pvData: 0x20010eb0, pc = 0x201765ac, xstatus 0x200004020, flags 0x1, nesting 0, non-zero GPR:
[ ] NVRM: OBJPMU Async: ra = 000000002018c3a0 sp = 0000000020025c10 tp = 0000000020025fd8 t1 = 0000000000000001
[ ] NVRM: OBJPMU Async: s0 = 0000000020010000 s1 = 00000000200468f0 a0 = 000000002005a580 a1 = 0000000020025c14
[ ] NVRM: OBJPMU Async: a2 = 0000000020025d10 a3 = 0000000020025d10 a4 = 0000000000000007 a5 = 000000002005a538
[ ] NVRM: OBJPMU Async: a7 = 000000002009a590 s2 = 00000000000bd358 s3 = 0000000020025d10 s4 = 00000000200468f0
[ ] NVRM: OBJPMU Async: s5 = 0000000020081ea0 s6 = 0000000020013000 s7 = 0000000020011000 s8 = 0000000020047fd0
[ ] NVRM: OBJPMU Async: s9 = 0000000020047718 s10 = 0000000000000015 s11 = 0000000020047648 t3 = 0000000000000002
[ ] NVRM: OBJPMU Async: t4 = 0000000000000001 t5 = 0000000000000008
[ ] NVRM: OBJPMU Async: MPU dump (enabled entries only, all numbers are hex):
[ ] NVRM: OBJPMU Async: # VA Start - VA End -> PHYS Size Cached?
[ ] NVRM: OBJPMU Async: 0 20000400 - 20007c00 -> 181000 7800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1 2000a000 - 2000b000 -> 188800 1000 N u:--- k:r-- tgt: DTCM
[ ] NVRM: OBJPMU Async: 2 2000b400 - 2000c400 -> 189800 1000 N u:r-- k:r-- tgt: DTCM
[ ] NVRM: OBJPMU Async: 3 2000c800 - 2000f000 -> 18a800 2800 N u:--- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 4 2000f400 - 20013c00 -> 18d000 4800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 5 20014000 - 20015800 -> 191800 1800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 6 20015c00 - 20016400 -> 193000 800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 7 20016800 - 20017000 -> 193800 800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 8 2009a400 - 2009ac00 -> 194000 800 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 9 20162400 - 20166c00 -> 101000 4800 N u:--- k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: a 20167000 - 2016b000 -> 105800 4000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: b 201bb400 - 201c2c00 -> 109800 7800 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: c c0000000 - c4000000 -> 2000000000000000 4000000 N u:rw- k:rw- tgt: PRIV
[ ] NVRM: OBJPMU Async: d 201c5000 - 201c5400 -> 1abc00 400 Y u:--- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: e 201c3c00 - 201c4c00 -> 194800 1000 Y u:--- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: f 2018e000 - 2018f000 -> 111000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 10 20197000 - 20198000 -> 112000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 11 20189000 - 2018a000 -> 113000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 12 20193000 - 20194000 -> 114000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 13 201b5000 - 201b6000 -> 115000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 14 20188000 - 20189000 -> 116000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 15 20187000 - 20188000 -> 117000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 16 201b1000 - 201b2000 -> 118000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 17 20072000 - 20073000 -> 196000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 18 2009d000 - 2009e000 -> 197000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 19 20025000 - 20026000 -> 198000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1a 20046000 - 20047000 -> 199000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1b 20048000 - 20049000 -> 19a000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1c 2002b000 - 2002c000 -> 19b000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1d 2002c000 - 2002d000 -> 19c000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1e 200a5000 - 200a6000 -> 19d000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 1f 20078000 - 20079000 -> 19e000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 20 20047000 - 20048000 -> 19f000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 21 2005a000 - 2005b000 -> 1a0000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 22 20067000 - 20068000 -> 1a1000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 23 2006a000 - 2006b000 -> 1a2000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 24 20081000 - 20082000 -> 1a3000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 25 20053000 - 20054000 -> 1a4000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 26 20080000 - 20081000 -> 1a5000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 27 20075000 - 20076000 -> 1a6000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 28 20077000 - 20078000 -> 1a7000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 29 2018b000 - 2018c000 -> 119000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 2a 2007b000 - 2007c000 -> 1a8000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 2b 2018a000 - 2018b000 -> 11a000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 2c 2018c000 - 2018d000 -> 11b000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 2d 20183000 - 20184000 -> 11c000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 2e 20185000 - 20186000 -> 11d000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 2f 20186000 - 20187000 -> 11e000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 30 20198000 - 20199000 -> 11f000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 31 20191000 - 20192000 -> 120000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 32 2004a000 - 2004b000 -> 1a9000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 33 201a2000 - 201a3000 -> 121000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 34 2007a000 - 2007b000 -> 1aa000 1000 N u:rw- k:rw- tgt: DTCM
[ ] NVRM: OBJPMU Async: 35 2019c000 - 2019d000 -> 122000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: 36 20192000 - 20193000 -> 123000 1000 N u:r-x k:r-x tgt: ITCM
[ ] NVRM: OBJPMU Async: Reservation (0~128): 11111111 11111111 11111111 11111111 11111111 11111111 11111110 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ ] NVRM: OBJPMU Async: Software MPU list:
[ ] NVRM: OBJPMU Async: # task# ref# mpuidx mpuref VA => PA (SIZE) ATTR
[ ] NVRM: OBJPMU Async: [113] 0 1 0x e 1 201c3c00 => 194800 (1000) 0x40018
[ ] NVRM: OBJPMU Async: [114] 0 1 0x d 1 201c5000 => 1abc00 (400) 0x40018
[ ] NVRM: OBJPMU Async: [115] 0 1 0x c 1 c0000000 => 2000000000000000 (4000000) 0x1b
[ ] NVRM: OBJPMU Async: [116] 0 1 0x b 1 201bb400 => 109800 (7800) 0x2d
[ ] NVRM: OBJPMU Async: [117] 0 1 0x a 1 20167000 => 105800 (4000) 0x2d
[ ] NVRM: OBJPMU Async: [118] 0 1 0x 9 1 20162400 => 101000 (4800) 0x28
[ ] NVRM: OBJPMU Async: [119] 0 1 0x 8 1 2009a400 => 194000 (800) 0x1b
[ ] NVRM: OBJPMU Async: [120] 0 1 0x 7 1 20016800 => 193800 (800) 0x1b
[ ] NVRM: OBJPMU Async: [121] 0 1 0x 6 1 20015c00 => 193000 (800) 0x1b
[ ] NVRM: OBJPMU Async: [122] 0 1 0x 5 1 20014000 => 191800 (1800) 0x1b
[ ] NVRM: OBJPMU Async: [123] 0 1 0x 4 1 2000f400 => 18d000 (4800) 0x1b
[ ] NVRM: OBJPMU Async: [124] 0 1 0x 3 1 2000c800 => 18a800 (2800) 0x18
[ ] NVRM: OBJPMU Async: [125] 0 1 0x 2 1 2000b400 => 189800 (1000) 0x9
[ ] NVRM: OBJPMU Async: [126] 0 1 0x 1 1 2000a000 => 188800 (1000) 0x8
[ ] NVRM: OBJPMU Async: [127] 0 1 0x 0 1 20000400 => 181000 (7800) 0x1b
[ ] NVRM: OBJPMU Async: Trace buffer full. Entries may have been lost.
[ ] NVRM: OBJPMU Async: Tracebuffer operates in stack mode and has 13 entries (most recent first):
[ ] NVRM: OBJPMU Async: [ 0] = 20163710
[ ] NVRM: OBJPMU Async: [ 1] = 20163eac
[ ] NVRM: OBJPMU Async: [ 2] = 20163ef2
[ ] NVRM: OBJPMU Async: [ 3] = 201650be
[ ] NVRM: OBJPMU Async: [ 4] = 201664da
[ ] NVRM: OBJPMU Async: [ 5] = 20164d52
[ ] NVRM: OBJPMU Async: [ 6] = 201765ac
[ ] NVRM: OBJPMU Async: [ 7] = 2018c39c
[ ] NVRM: OBJPMU Async: [ 8] = 2018c3d0
[ ] NVRM: OBJPMU Async: [ 9] = 2018c246
[ ] NVRM: OBJPMU Async: [10] = 2018c25a
[ ] NVRM: OBJPMU Async: [11] = 2018c2b8
[ ] NVRM: OBJPMU Async: [12] = 2019ce08
[ ] NVRM: OBJPMU Async: RSTAT3 = 0x00000000 00000002
[ ] NVRM: OBJPMU Async: RSTAT4 = 0x00000000 00000000
[ ] NVRM: OBJPMU Async: IRQMASK = 0x010438d0
[ ] NVRM: OBJPMU Async: IRQTYPE = 0x00000000
[ ] NVRM: OBJPMU Async: IRQDEST = 0x010000d0
[ ] NVRM: OBJPMU Async: INTRSTAT = 0x00000009
[ ] NVRM: OBJPMU Async: DBGCTL = 0x0000d542
[ ] NVRM: OBJPMU Async: CPUCTL = 0x00000080
[ ] NVRM: OBJPMU Async: EXTERRSTAT = 0x00000000
[ ] NVRM: OBJPMU Async: EXTERRADDR = 0x00000000
[ ] NVRM: OBJPMU Async: EXTERRINFO = 0x00000000
[ ] NVRM: OBJPMU Async: HUBERRSTAT = 0x00000000
[ ] NVRM: OBJPMU Async: XSTATUS = 0x0000000200000020
[ ] NVRM: OBJPMU Async: MAILBOX0 = 0x6dba2000
[ ] NVRM: OBJPMU Async: MAILBOX1 = 0x80600004
[ ] NVRM: OBJPMU Async: IRQSTAT = 0x00000081
[ ] NVRM: OBJPMU Async: DMACTL = 0x00000000
[ ] NVRM: OBJPMU Async: DMATRFCMD = 0x00000610
[ ] NVRM: OBJPMU Async: DMATRFBASE = 0x03fba9d0
[ ] NVRM: OBJPMU Async: DMATRFMOFFS = 0x00012f00
[ ] NVRM: OBJPMU Async: DMATRFFBOFFS = 0x00012f00
[ ] NVRM: OBJPMU Async: IDLESTATE = 0x00100009
[ ] NVRM: OBJPMU Async: FBIF_CTL = 0x00000090
[ ] NVRM: OBJPMU Async: FBIF_CTL2 = 0x00000001
[ ] NVRM: Possible bad register read: addr: 0x10a100, regvalue: 0xbadf5720, error code: Unknown SYS_PRI_ERROR_CODE
[ ] NVRM: Possible bad register read: addr: 0x10a240, regvalue: 0xbadf5720, error code: Unknown SYS_PRI_ERROR_CODE
[ ] NVRM: bp @ <fileid:0x000736>:1302 (reason=112)
[ ] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] -------------------------- END ASSERT INFO DUMP --------------------------
[ ] First error recorded: 539 NVRM Generic falcon error
[ ] JavaScript stack trace:
[ ] NVRM: <<<<<<<<<<<< FALCON DEBUG INFO GPU 0 - START >>>>>>>>>>>>
[ ] NVRM: Falcon engine: : 0x0000000c
[ ] NVRM: Falcon core revision : 0x0060
[ ] NVRM: Falcon security model : 0x03
[ ] NVRM: Peregrine Registers:
[ ] NVRM: OS : 0x01caba13
[ ] NVRM: PC (lo32) : 0x20165074
[ ] NVRM: CPUCTL : 0x00000080
[ ] NVRM: IDLESTATE : 0x00100009
[ ] NVRM: MAILBOX0 : 0x6dba2000
[ ] NVRM: MAILBOX1 : 0x80600004
[ ] NVRM: IRQSTAT : 0x00400011
[ ] NVRM: IRQMODE : 0x0184fc24
[ ] NVRM: IRQMASK : 0x010438d0
[ ] NVRM: IRQDEST : 0x010000d0
[ ] NVRM: IRQDELEG : 0x000438d0
[ ] NVRM: DMACTL : 0x00000000
[ ] NVRM: DMATRFCMD : 0x00000610
[ ] NVRM: DMATRFBASE : 0x03fba9d0
[ ] NVRM: DMATRFMOFFS : 0x00012f00
[ ] NVRM: DMATRFFBOFFS : 0x00012f00
[ ] NVRM: PRIVERR_STAT : 0x00000000
[ ] NVRM: PRIVERR_INFO : 0x00000000
[ ] NVRM: PRIVERR_ADDR : 0x0000000000000000
[ ] NVRM: HUBERR_STAT : 0x00000000
[ ] NVRM: SCTL : 0xbadf5720
[ ] NVRM: SCTL1 : 0x0000000f
[ ] NVRM: RISC-V Core State:
[ ] NVRM: RSTAT0 : 0x0000000000000000
[ ] NVRM: RSTAT3 : 0x0000000000000002
[ ] NVRM: RSTAT4 : 0x00000000000007f2
[ ] NVRM: PC : 0x0000000020165074
[ ] NVRM: SSTATUS : 0x0000000200000120
[ ] NVRM: SIE : 0x0000000000000002
[ ] NVRM: SIP : 0x0000000000000022
[ ] NVRM: SCFG : 0x0000000000001000
[ ] NVRM: FCSR : (no permission)
[ ] NVRM: DCSR : (no permission)
[ ] NVRM: SSCRATCH : 0x0000000000000000
[ ] NVRM: SSCRATCH2 : 0x0000000000000000
[ ] NVRM: SEPC : 0x0000000020166b1a
[ ] NVRM: SRSP : 0x000000000000000a
[ ] NVRM: SSPM : 0x0000000000030055
[ ] NVRM: SCAUSE : 0x8000000000000001
[ ] NVRM: STVAL : 0x0000000000000000
[ ] NVRM: MDBGCTL : (no permission)
[ ] NVRM: Trace buffer full. Entries may have been lost.
[ ] NVRM: Tracebuffer has 12 entries. Starting with latest.
[ ] NVRM: TRACE[0] = 0x 20166b1a
[ ] NVRM: TRACE[1] = 0x 20163ef2
[ ] NVRM: TRACE[2] = 0x 201650be
[ ] NVRM: TRACE[3] = 0x 201664da
[ ] NVRM: TRACE[4] = 0x 20164d52
[ ] NVRM: TRACE[5] = 0x 201765ac
[ ] NVRM: TRACE[6] = 0x 2018c39c
[ ] NVRM: TRACE[7] = 0x 2018c3d0
[ ] NVRM: TRACE[8] = 0x 2018c246
[ ] NVRM: TRACE[9] = 0x 2018c25a
[ ] NVRM: TRACE[10] = 0x 2018c2b8
[ ] NVRM: TRACE[11] = 0x 2019ce08
[ ] NVRM: <<<<<<<<<<<<< FALCON DEBUG INFO GPU 0 - END >>>>>>>>>>>>>
[ ] NVRM:
!! ^ ^ ^ ^ ^ * PMU-RISCV HALTED! * ^ ^ ^ ^ ^ !!
!! Please file a bug starting from the first line !!
!! with "OBJPMU Async" to the current line. !!
!!!!!!!!!!!!!!!!!!!!!!!NVRM: bp @ <fileid:0x0006f2>:136 (reason=112)
[ ] NVRM:
[ ] NVRM: threadId: 0x0000003f2 irql: 0x000000000 flags: 0x020
[ ] NVRM: enterTime: 0x18987a8d678c2790 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900
[ ] NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
[ ] NVRM: Timed out waiting for seqDesc=0x00000075
[ ] NVRM: bp @ <fileid:0x0006d3>:7151 (reason=112)
[ ] NVRM:
[ ] NVRM: Timed out while waiting for PMU command completion
[ ] NVRM: Failed to execute RPC (status=0x00000065, unit=0x13, func=0x00, block=0x01)
[ ] NVRM: bp @ <fileid:0x0006dd>:294 (reason=112)
ERROR: bp @ <fileid:0x0005e4>:1445
[ ] NVRM:
[ ] NVRM: Assertion failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from 0x00000000019b5d38
[ ] bp @ <fileid:0x0005e4>:1445
MODS is exiting with failure after assert #5. Breakpoint limit exceeded.
Error Code = 000000000539 (NVRM Generic falcon error)
ERROR: bp @ <fileid:0x00000c>:841
ERROR: Detected a recursive breakpoint while handling -exit_on_breakpoint. Aborting!!
[ 0] NVRM: OBJPMU Async: 19 20025000 - 20026000 -> 198000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1a 20046000 - 20047000 -> 199000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1b 20048000 - 20049000 -> 19a000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1c 2002b000 - 2002c000 -> 19b000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1d 2002c000 - 2002d000 -> 19c000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1e 200a5000 - 200a6000 -> 19d000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 1f 20078000 - 20079000 -> 19e000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 20 20047000 - 20048000 -> 19f000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 21 2005a000 - 2005b000 -> 1a0000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 22 20067000 - 20068000 -> 1a1000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 23 2006a000 - 2006b000 -> 1a2000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 24 20081000 - 20082000 -> 1a3000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 25 20053000 - 20054000 -> 1a4000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 26 20080000 - 20081000 -> 1a5000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 27 20075000 - 20076000 -> 1a6000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 28 20077000 - 20078000 -> 1a7000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 29 2018b000 - 2018c000 -> 119000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 2a 2007b000 - 2007c000 -> 1a8000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 2b 2018a000 - 2018b000 -> 11a000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 2c 2018c000 - 2018d000 -> 11b000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 2d 20183000 - 20184000 -> 11c000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 2e 20185000 - 20186000 -> 11d000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 2f 20186000 - 20187000 -> 11e000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 30 20198000 - 20199000 -> 11f000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 31 20191000 - 20192000 -> 120000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 32 2004a000 - 2004b000 -> 1a9000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 33 201a2000 - 201a3000 -> 121000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 34 2007a000 - 2007b000 -> 1aa000 1000 N u:rw- k:rw- tgt: DTCM
[ 0] NVRM: OBJPMU Async: 35 2019c000 - 2019d000 -> 122000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: 36 20192000 - 20193000 -> 123000 1000 N u:r-x k:r-x tgt: ITCM
[ 0] NVRM: OBJPMU Async: Reservation (0~128): 11111111 11111111 11111111 11111111 11111111 11111111 11111110 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0] NVRM: OBJPMU Async: Software MPU list:
[ 0] NVRM: OBJPMU Async: # task# ref# mpuidx mpuref VA => PA (SIZE) ATTR
[ 0] NVRM: OBJPMU Async: [113] 0 1 0x e 1 201c3c00 => 194800 (1000) 0x40018
[ 0] NVRM: OBJPMU Async: [114] 0 1 0x d 1 201c5000 => 1abc00 (400) 0x40018
[ 0] NVRM: OBJPMU Async: [115] 0 1 0x c 1 c0000000 => 2000000000000000 (4000000) 0x1b
[ 0] NVRM: OBJPMU Async: [116] 0 1 0x b 1 201bb400 => 109800 (7800) 0x2d
[ 0] NVRM: OBJPMU Async: [117] 0 1 0x a 1 20167000 => 105800 (4000) 0x2d
[ 0] NVRM: OBJPMU Async: [118] 0 1 0x 9 1 20162400 => 101000 (4800) 0x28
[ 0] NVRM: OBJPMU Async: [119] 0 1 0x 8 1 2009a400 => 194000 (800) 0x1b
[ 0] NVRM: OBJPMU Async: [120] 0 1 0x 7 1 20016800 => 193800 (800) 0x1b
[ 0] NVRM: OBJPMU Async: [121] 0 1 0x 6 1 20015c00 => 193000 (800) 0x1b
[ 0] NVRM: OBJPMU Async: [122] 0 1 0x 5 1 20014000 => 191800 (1800) 0x1b
[ 0] NVRM: OBJPMU Async: [123] 0 1 0x 4 1 2000f400 => 18d000 (4800) 0x1b
[ 0] NVRM: OBJPMU Async: [124] 0 1 0x 3 1 2000c800 => 18a800 (2800) 0x18
[ 0] NVRM: OBJPMU Async: [125] 0 1 0x 2 1 2000b400 => 189800 (1000) 0x9
[ 0] NVRM: OBJPMU Async: [126] 0 1 0x 1 1 2000a000 => 188800 (1000) 0x8
[ 0] NVRM: OBJPMU Async: [127] 0 1 0x 0 1 20000400 => 181000 (7800) 0x1b
[ 0] NVRM: OBJPMU Async: Trace buffer full. Entries may have been lost.
[ 0] NVRM: OBJPMU Async: Tracebuffer operates in stack mode and has 13 entries (most recent first):
[ 0] NVRM: OBJPMU Async: [ 0] = 20163710
[ 0] NVRM: OBJPMU Async: [ 1] = 20163eac
[ 0] NVRM: OBJPMU Async: [ 2] = 20163ef2
[ 0] NVRM: OBJPMU Async: [ 3] = 201650be
[ 0] NVRM: OBJPMU Async: [ 4] = 201664da
[ 0] NVRM: OBJPMU Async: [ 5] = 20164d52
[ 0] NVRM: OBJPMU Async: [ 6] = 201765ac
[ 0] NVRM: OBJPMU Async: [ 7] = 2018c39c
[ 0] NVRM: OBJPMU Async: [ 8] = 2018c3d0
[ 0] NVRM: OBJPMU Async: [ 9] = 2018c246
[ 0] NVRM: OBJPMU Async: [10] = 2018c25a
[ 0] NVRM: OBJPMU Async: [11] = 2018c2b8
[ 0] NVRM: OBJPMU Async: [12] = 2019ce08
[ 0] NVRM: OBJPMU Async: RSTAT3 = 0x00000000 00000002
[ 0] NVRM: OBJPMU Async: RSTAT4 = 0x00000000 00000000
[ 0] NVRM: OBJPMU Async: IRQMASK = 0x010438d0
[ 0] NVRM: OBJPMU Async: IRQTYPE = 0x00000000
[ 0] NVRM: OBJPMU Async: IRQDEST = 0x010000d0
[ 0] NVRM: OBJPMU Async: INTRSTAT = 0x00000009
[ 0] NVRM: OBJPMU Async: DBGCTL = 0x0000d542
[ 0] NVRM: OBJPMU Async: CPUCTL = 0x00000080
[ 0] NVRM: OBJPMU Async: EXTERRSTAT = 0x00000000
[ 0] NVRM: OBJPMU Async: EXTERRADDR = 0x00000000
[ 0] NVRM: OBJPMU Async: EXTERRINFO = 0x00000000
[ 0] NVRM: OBJPMU Async: HUBERRSTAT = 0x00000000
[ 0] NVRM: OBJPMU Async: XSTATUS = 0x0000000200000020
[ 0] NVRM: OBJPMU Async: MAILBOX0 = 0x6dba2000
[ 0] NVRM: OBJPMU Async: MAILBOX1 = 0x80600004
[ 0] NVRM: OBJPMU Async: IRQSTAT = 0x00000081
[ 0] NVRM: OBJPMU Async: DMACTL = 0x00000000
[ 0] NVRM: OBJPMU Async: DMATRFCMD = 0x00000610
[ 0] NVRM: OBJPMU Async: DMATRFBASE = 0x03fba9d0
[ 0] NVRM: OBJPMU Async: DMATRFMOFFS = 0x00012f00
[ 0] NVRM: OBJPMU Async: DMATRFFBOFFS = 0x00012f00
[ 0] NVRM: OBJPMU Async: IDLESTATE = 0x00100009
[ 0] NVRM: OBJPMU Async: FBIF_CTL = 0x00000090
[ 0] NVRM: OBJPMU Async: FBIF_CTL2 = 0x00000001
[ 0] NVRM: Possible bad register read: addr: 0x10a100, regvalue: 0xbadf5720, error code: Unknown SYS_PRI_ERROR_CODE
[ 0] NVRM: Possible bad register read: addr: 0x10a240, regvalue: 0xbadf5720, error code: Unknown SYS_PRI_ERROR_CODE
[ 0] NVRM: bp @ <fileid:0x000736>:1302 (reason=112)
[ 0]
[ 0] ** ModsDrvBreakPoint on GPU 0 [01:00.0] **
[ 0] First error recorded: 539 NVRM Generic falcon error
[ 0] JavaScript stack trace:
[ 0] NVRM: <<<<<<<<<<<< FALCON DEBUG INFO GPU 0 - START >>>>>>>>>>>>
[ 0] NVRM: Falcon engine: : 0x0000000c
[ 0] NVRM: Falcon core revision : 0x0060
[ 0] NVRM: Falcon security model : 0x03
[ 0] NVRM: Peregrine Registers:
[ 0] NVRM: OS : 0x01caba13
[ 0] NVRM: PC (lo32) : 0x20165074
[ 0] NVRM: CPUCTL : 0x00000080
[ 0] NVRM: IDLESTATE : 0x00100009
[ 0] NVRM: MAILBOX0 : 0x6dba2000
[ 0] NVRM: MAILBOX1 : 0x80600004
[ 0] NVRM: IRQSTAT : 0x00400011
[ 0] NVRM: IRQMODE : 0x0184fc24
[ 0] NVRM: IRQMASK : 0x010438d0
[ 0] NVRM: IRQDEST : 0x010000d0
[ 0] NVRM: IRQDELEG : 0x000438d0
[ 0] NVRM: DMACTL : 0x00000000
[ 0] NVRM: DMATRFCMD : 0x00000610
[ 0] NVRM: DMATRFBASE : 0x03fba9d0
[ 0] NVRM: DMATRFMOFFS : 0x00012f00
[ 0] NVRM: DMATRFFBOFFS : 0x00012f00
[ 0] NVRM: PRIVERR_STAT : 0x00000000
[ 0] NVRM: PRIVERR_INFO : 0x00000000
[ 0] NVRM: PRIVERR_ADDR : 0x0000000000000000
[ 0] NVRM: HUBERR_STAT : 0x00000000
[ 0] NVRM: SCTL : 0xbadf5720
[ 0] NVRM: SCTL1 : 0x0000000f
[ 0] NVRM: RISC-V Core State:
[ 0] NVRM: RSTAT0 : 0x0000000000000000
[ 0] NVRM: RSTAT3 : 0x0000000000000002
[ 0] NVRM: RSTAT4 : 0x00000000000007f2
[ 0] NVRM: PC : 0x0000000020165074
[ 0] NVRM: SSTATUS : 0x0000000200000120
[ 0] NVRM: SIE : 0x0000000000000002
[ 0] NVRM: SIP : 0x0000000000000022
[ 0] NVRM: SCFG : 0x0000000000001000
[ 0] NVRM: FCSR : (no permission)
[ 0] NVRM: DCSR : (no permission)
[ 0] NVRM: SSCRATCH : 0x0000000000000000
[ 0] NVRM: SSCRATCH2 : 0x0000000000000000
[ 0] NVRM: SEPC : 0x0000000020166b1a
[ 0] NVRM: SRSP : 0x000000000000000a
[ 0] NVRM: SSPM : 0x0000000000030055
[ 0] NVRM: SCAUSE : 0x8000000000000001
[ 0] NVRM: STVAL : 0x0000000000000000
[ 0] NVRM: MDBGCTL : (no permission)
[ 0] NVRM: Trace buffer full. Entries may have been lost.
[ 0] NVRM: Tracebuffer has 12 entries. Starting with latest.
[ 0] NVRM: TRACE[0] = 0x 20166b1a
[ 0] NVRM: TRACE[1] = 0x 20163ef2
[ 0] NVRM: TRACE[2] = 0x 201650be
[ 0] NVRM: TRACE[3] = 0x 201664da
[ 0] NVRM: TRACE[4] = 0x 20164d52
[ 0] NVRM: TRACE[5] = 0x 201765ac
[ 0] NVRM: TRACE[6] = 0x 2018c39c
[ 0] NVRM: TRACE[7] = 0x 2018c3d0
[ 0] NVRM: TRACE[8] = 0x 2018c246
[ 0] NVRM: TRACE[9] = 0x 2018c25a
[ 0] NVRM: TRACE[10] = 0x 2018c2b8
[ 0] NVRM: TRACE[11] = 0x 2019ce08
[ 0] NVRM: <<<<<<<<<<<<< FALCON DEBUG INFO GPU 0 - END >>>>>>>>>>>>>
[ 0] NVRM:
[ 0]
[ 0] NVRM: threadId: 0x0000003f2 irql: 0x000000000 flags: 0x020
[ 0] NVRM: enterTime: 0x18987a8d678c2790 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900
[ 0] NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
[ 0] NVRM: Timed out waiting for seqDesc=0x00000075
[ 0] NVRM: bp @ <fileid:0x0006d3>:7151 (reason=112)
[ 0]
[ 0] NVRM: Timed out while waiting for PMU command completion
[ 0] NVRM: Failed to execute RPC (status=0x00000065, unit=0x13, func=0x00, block=0x01)
[ 0] NVRM: bp @ <fileid:0x0006dd>:294 (reason=112)
[ 0]
[ 0] NVRM: Assertion failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from 0x00000000019b5d38
[ 0] bp @ <fileid:0x0005e4>:1445
[ 0]
[ 0] MODS is exiting with failure after assert #5. Breakpoint limit exceeded.
[ 0]
[ 0]
[ 0]
[ 0]
[ 0]
[ 0] Beginning GPU shut down
[ 0] Shutdown : GPU devices not initialized, skipping GPU nvlink shutdown
[ 0] IRQ statistics:
[ 0] num IRQs: 1
[ 0] avg IRQ delay: 0us
[ 0] min IRQ delay: 0us
[ 0] max IRQ delay: 0us
[ 0] NVRM: Assertion failed: 0x00000000018c25ed
[ 0] bp @ <fileid:0x00000c>:841
[ 0] Detected a recursive breakpoint while handling -exit_on_breakpoint. Aborting!!
----------call stack----------
I'll appreciate any help.
Thanks!
 Заголовок сообщения: Re: Nvidia Zotac 3070 LHR crashes while running mods on it
СообщениеДобавлено: 02 мар 2026, 18:38
Sounds likepower problem.
СообщениеДобавлено: 02 мар 2026, 21:45
Any idea what to check?
СообщениеДобавлено: 30 апр 2026, 19:47
For modified 3070 16GB, you must change the power setting in Nvidia App to full power or it will crash.
В этой теме нет новых непрочитанных сообщений. RTX 3060ti LHR -> Замена GPU без LHR
yellowfox
22 мар 2022, 23:26
yellowfox Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GALAX RTX 3070 converted into 3060TI LHR with ram bank B1 C0 with errors
HeatElectronics
2692
27 июн 2023, 18:37
jeffersonsilva998 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte RTX 3070 LHR Gaming проблемы на холодную
INVIS
28 окт 2023, 17:47
В этой теме нет новых непрочитанных сообщений. ASUS 3070 TI (LHR)All Voltages Present, NO Picture
aysatx
03 янв 2025, 23:30
jim62 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI 3070 ti gaming X trio 8G LHR зашит неродной BIOS
StayeR
13
3265
29 дек 2024, 19:44
sashok289 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 98
