Заголовок сообщения: Asus STRIX GTX970 resets PC as soon as you install Driver
Добавлено: 21 мар 2018, 16:39
Зарегистрирован: 12 май 2014, 21:17 Наличности на руках: 70.07 Сообщения: 50 Откуда: Iran
Hi everyone,
A customer has brought an Asus Strix GTX970 which is working fine without drivers, while installing graphics drivers screen goes black and system resets completely, anyone had a similar issue and where to check for? Can it be a VRM or Memory related problem or you think it is related to GPU itself?
recordsman
Заголовок сообщения: Re: Asus STRIX GTX970 resets PC as soon as you install Driver
