Текущее время: 17 июн 2024, 19:47
 Заголовок сообщения: 100664987 rev.A
СообщениеДобавлено: 08 янв 2020, 15:49
Интересует p/n микросхемы пзу.https://yadi.sk/d/V6s5RWMr9ob49Q Есть ли возможность проверить?
 Заголовок сообщения: Re: 100664987 rev.A
СообщениеДобавлено: 08 янв 2020, 16:24
Все хорошо.
Multipart flash image found. Reparsing...
Parsing multipart flash image....... Flash ROM image
Part 1...
Parsing container segment....... Flash ROM part 1
Segment: BOOTFW_DIR
Parsing segment....... BOOTFW_DIR
End parsing segment... BOOTFW_DIR
Segment: GENERAL_DATA
Parsing segment....... GENERAL_DATA
End parsing segment... GENERAL_DATA
Segment: IAP
Parsing segment....... IAP
End parsing segment... IAP
Segment: BOOTFW
Segment: RAP
Parsing segment....... RAP
End parsing segment... RAP
Segment: CAP
Parsing segment....... CAP
End parsing segment... CAP
Segment: SAP
Parsing segment....... SAP
End parsing segment... SAP
Segment: SFW
Parsing segment....... SFW
End parsing segment... SFW
Segment: SHELL
Parsing segment....... SHELL
End parsing segment... SHELL
End parsing container segment... Flash ROM part 1
Part 2...
Parsing container segment....... Flash ROM part 2
Segment: BOOTFW_DIR
Segment: IAP
Segment: BOOTFW
Segment: RAP
Segment: CAP
Segment: SAP
Segment: SFW
Segment: SHELL
End parsing container segment... Flash ROM part 2
FLASH ROM Info
Image size............... : 524288
QNR Revisions:
Flash ROM image.......... : 1
CAP
Validation Key........... : 0x00000020
Fam ID................... : 0x58 (Grenada)
Fam Member............... : 0x6
Head count............... : 2
Date..................... : 10 апр 2012
SN....................... : S1D1VF5Q
PCB SN................... : 0000M239L0G9
PCB PN................... : яяяяяяяяяя
WWN...................... : 5000C5004B41D5EC
MDL1..................... : ST1000DM003-9YN162
MDL2..................... : ST1000DM003-9YN162
Capacity................. : 1953525168
RAP
Format revision.......... : 0x0002
Contents revision........ : 0x61020000
Number Sys Zones......... : 1
Number User Zones........ : 30
Heads count.............. : 2
FW Implementation Key.... : 0x16
SAP
Addr 0................... : 0x0001D400
Addr 1................... : 0x40002000
Fam ID................... : 0x58, (Grenada)
Servo FW rev code........ : 0xBB99
Max head................. : 1
Seek mode................ : 2020
Flags.................... : 1A09
RRO mode................. : 0005
Preamp type.............. : 03B2
Heads polarity........... : 00 00 00 00 00 00 00 00 00 00
Logical head map......... : 00 01 02 03 04 05 06 07 08 09
Phys head maps........... : 00 01 02 03 04 05 06 07 08 09
CODE info
Bank 0
ProdType................. :
Controller FW Rev........ : 04021425
Customer Release......... : CC4B
Changelist............... : 00439010
Build date / time........ : 02.04.12 14:25:41
Package Global ID........ : 00188399
Package Builder ID....... :
Build Rev................ :
Package Rev.............. : BL01AZ
Pkg P/N.................. : 100705100
Servo FW................. : B3A7 / ---- / ---- / ----
Package Version.......... : .BL01AZ.CC4B
Pkg CFW Ver.............. : .00439010.00188399
Bank 1
Серийники платы и банки убедитесь, что родные.
На плате нужно сканером 2D читать серийник, например программой на смартфоне.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung R-540 BREMEN2-L REV:1.0 (Windows 7) Заменил материнку с Bremen 2-L REV:1.0 на Bremen-C REV:1.1 и тепер
в форуме Samsung
Ljagasu555
5224
04 окт 2016, 15:54
Ljagasu555 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. N164HGE-L12 REV.C1 (N164HGE-L12 REV.C1) N164HGE-L12 REV.C1
в форуме Sony
ornellit
4657
13 мар 2019, 10:29
elmont33 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ET2012E rev.2.00G (ET2012E rev.2.00G) нет изображения и подсветки
cloze
03 окт 2019, 00:27
kalya Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell studio 1537 (PP33L) (Quanta FM7 rev D PWB T0126 rev A00) Нужен биос
в форуме Dell
Victor_2
3183
02 дек 2014, 17:31
Victor_2 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. hp 15-b058sr (da0u36mb6d0 rev d ) da0u36mb6d0 rev d стартует нет ИЗО
max83461
22 дек 2014, 10:15
