Зарегистрирован: 10 янв 2014, 01:59 Наличности на руках: -3.85 Сообщения: 279 Откуда: Kraków
I changed chip and I have 40V on two capacitor (on the photo). But problem is, when I connect kable screen I have only 20V. I notice when screen has over 25V is starting high lighting.I changed this capacitor from screen but sytuation is the some. Any ide?
Solution. I changed chip and I have 40V on two capacitor (on the photo red). But problem is, when I connect kable screen I have only 20V(on the photo red). Problem was with one resistor( photo yellow). It had 10K but need to be 20K. That all problems.
