Текущее время: 21 ноя 2026, 03:50
 Заголовок сообщения: A1989 820-00850-a (missing parts) no power
СообщениеДобавлено: 31 июл 2020, 18:59
i have a macbook A1989 that has taken water, i cleaned pcb with ultrasound and i noticed this missing component. It is not present from the brd scheme I have available, how do I identify it?
can someone help me?
 Заголовок сообщения: Re: A1989 820-00850-a (missing parts) no power
СообщениеДобавлено: 31 июл 2020, 19:27
Q8401-SI7812DN
В личке все ответы платные.
СообщениеДобавлено: 31 июл 2020, 21:34
This is not Q8401
There are no elements in this position.
This is a damaged conductive track.
You can just put a jumper.
But this track itself could not be damaged. Either there is a short circuit after it, or it is specially damaged by someone.
помог, нажми спасибо
СообщениеДобавлено: 01 авг 2020, 10:08
HanChengui писал(а):
SI7812DN
I was referring to the small component at the top of the capacitors, in the diagram it is not shown but on the pcb it was present
СообщениеДобавлено: 02 авг 2020, 13:00
sdogs писал(а):
a1989 (820-00850) тач бар
pls :cry_ing: :cry_ing: :cry_ing:
СообщениеДобавлено: 02 авг 2020, 17:19
Indeed, there is an element.
But let's think logically.
The bus on which this element is installed PPVOUT_S0_LCDBKLT.
This is the display backlight bus.
Where can this bus go? In fact, only on the J8500 connector, for 43 pins.
Check if you have a connection from the PPVOUT_S0_LCDBKLT line to pins 43.
Most likely there is no connection. And according to the scheme, there is a connection. This means that this element has a safety function.
This can be a zero resistor, fuse, or inductance.
I think any 50-60V fuse with a power of about 1W (55V * 0.015A = 0.825W) will do.
Can be replaced with a jumper for testing. But be sure to check that there was no short circuit on the side of the J8500 connector (this could cause this element to fail)
It's so easy
СообщениеДобавлено: 03 авг 2020, 08:41
thanks ;-), I will follow your suggestion, I am learning and I am a beginner
СообщениеДобавлено: 16 апр 2021, 18:18
R 0.8 Ohm
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. a1989 (820-00850) тач бар
в форуме Apple
rilya
05 июл 2019, 14:49
hardlviv Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1989 (2018г) (820-00850-a) нет подсветки
в форуме Apple
grits
29 апр 2020, 07:15
grits Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. A1989 (820-00850-A) Подскажите номинал резисторов
в форуме Apple
Mich6el
08 май 2020, 00:16
Mich6el Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. A1989 (820-00850-B) PPVOUT_S0_LCDBKLT
в форуме Apple
Neodim
16 апр 2021, 18:10
LogBolder Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. a1989 (820-00850) сильно тормозит!!!
в форуме Apple
dargin92
11
2867
28 авг 2020, 09:05
x_Fil Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 36
