Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без коррозии https://vlab.su/viewtopic.php?f=51&t=113184 |
kosmo555 [ 09 мар 2021, 15:02 ] | |
Заголовок сообщения: | Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без коррозии |
recently they brought me this mac, and it turns on it does the reset and then works with full fan and no chime and no video also no sign of corrosion in the board, any idea? Недавно они принесли мне этот Mac, и он включается, он выполняет сброс, а затем работает с полным вентилятором, без звука и видео, а также без признаков коррозии на плате, есть идеи? |
gsmprofi [ 09 мар 2021, 16:44 ] | |
Заголовок сообщения: | Re: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без корроз |
Here is an idea: Find an experienced technician with appropriate tools, spares and knowledge. He will bring this A1466 to life for a fair amount of money. |
Shooter75 [ 09 мар 2021, 17:39 ] | |
High fan spinning - usually result of one or more sensors faulting. - LIO-board with flexcable replacement, - trackpad with flexcable replacement, - battery replacement, - SMC reballing, No image - be sure, if realy no image or no BKLT? Do You have any image at external miniDP port? It's possible, that screen eDP cable is damaged. No chime - flexcable and connectors from MLB to LIO-board was damaged, or no 5V_S4/1V5_S0SW_AUDIO. If You have spare parts - verify integrity of flexcable and it's connectors at MLB and LIO. At 11 an 13 pins is placed SMBUS for FinStack thermal sensor,soldered at LIO board. |
kosmo555 [ 10 мар 2021, 13:00 ] | |
Shooter75 писал(а): High fan spinning - usually result of one or more sensors faulting. - LIO-board with flexcable replacement, - trackpad with flexcable replacement, - battery replacement, - SMC reballing, No image - be sure, if realy no image or no BKLT? Do You have any image at external miniDP port? It's possible, that screen eDP cable is damaged. No chime - flexcable and connectors from MLB to LIO-board was damaged, or no 5V_S4/1V5_S0SW_AUDIO. If You have spare parts - verify integrity of flexcable and it's connectors at MLB and LIO. At 11 an 13 pins is placed SMBUS for FinStack thermal sensor,soldered at LIO board. hello there, i have a donor a1466 and i allready checked lcd panel + io cable i tried also to external monitor with mini display port and nothing, i did all the power rail measurements below : PPBUS_G3H 8.56v PPBUS_S5_HS_COMPUTING_ISNS 8.55v PPBUS_S5_HS_OTHER_ISNS 8.55v PPDCIN_G3H_ISOL 14.94v PPDCIN_G3H 14.94v PP3V42_G3H 3.41v PPVRTC_G3H 3.31v PP5V_S5 5.08v PP5V_S4RS3 5.08v PP5V_S0 5.08v PP3V3_S5 3.31v PP3V3_S4 3.31v PP3V3_SUS 3.31v PP3V3_S3 3.31v PP3V3_S0 3.31v PP3V3_S4SW_SNS 3.31v PP3V3_S0SW_SSD 3.32v PP3V3_S4_TBTAPWR 3.31v PP1V8_S3 1.78v PP1V2_S3 1.19v PP1V05_SUS 1.04v PP1V5_S0 1.49v PP0V6_S0_DDRVTT 0.59v PP1V05_S0 1.04v PP1V05_S0SW_PCH_HSIO 1.03v PPHV_S0SW_LCDBKLT 0v PP15V_TBT 0v PP3V3_TBTLC 3.30v PP1V05_TBTCIO 0.98v PPVCC_S0_CPU 1.79v Posted after 2 hours 8 minutes 2 seconds: Re: Α1466 (820-00165-A) fanspins!no video, no chime, no corrosion. фанспины! без видео, без звонка, без коррозии i just noticed blown F7700, i replaced and checked with my donor panel still nothing, customer said lcd was flickering and for days and suddenly black screen, then it give the macbook to 2 different service stores, after that she brought it to me i also noticed that someone did rework on cpu it has flux around it and the protective black film burned, so i figured out that , from begining the problem was on lcd panel and F7700 fuse, then the guy that reworked the cpu damaged it, and the mac stopped working. Topic Closed thanks for the help. |
