Заголовок сообщения: HP 15-p076na ( DAY11AMB6E0) Conversion form DIS to UMA issues
Добавлено: 07 окт 2017, 15:32
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 20.00 Сообщения: 198 Откуда: Ghana
Hello everyone, the motherboard for this laptop was replaced with one that has discrete GPU, and this has caused some HEAT SINK problems because the original heat sink was for a UMA configuration so, as a result of that I have to convert the board to UMA. My question is, do I need to reflash the bios after conversion and if so, what BID should I use?
Uomo
Заголовок сообщения: Re: HP 15-p076na ( DAY11AMB6E0) Conversion form DIS to UMA issues
there is such a fee in UMA repair, tomorrow I will be able to do a detailed photo, and see what the difference is. in my board is BID0227D ready-made firmware is HERE (cut from the official site)
google translate
abuholm
Добавлено: 09 окт 2017, 14:05
Ok thanks I will wait for your post.
Uomo
Сейчас этот форум просматривают: Nero85, vlad56 и гости: 9
