Текущее время: 11 июн 2024, 11:40
Страница 1 из 1 [ 1 сообщение ] |
andromedax
Заголовок сообщения: OMEN HP Laptop (Quanta G35D) +VCCGT problem Добавлено: 03 янв 2020, 21:37 |
Сообщения: 262 Откуда: Alicante, Spain
OMEN HP Laptop +VCCGT problem
This OMEN HP Laptop is water damaged.
At first it had a short in +VIN rail due to mosfet PQ4007 being short-circuit.
After replace PQ4007, laptop start, and fans are spinning, but no lcd image.
It drains 1.2 amps from lab psu, and after 20 seconds, it drains only 0.6 amps.
+VCCGT voltage is present only half a second, but +VCC_CORE is present that 20 seconds.
I cleaned the motherboard with isopropyl alcohol, and there are no sings of corrosion.
Nothing is getting warmer, but i suspect PQ4007 killed the cpu.
NVVDD and NVVDDS voltage are present since power-on.
Can I make any crucial measurement to test the cpu? --------
