i got this laptop with a messed keyboard connector and some pins have abnormal diode values the keyboard connector is 40 pin and altered pin diode mode value are pin number 5 with ground 20 with gorund 34 with OL 35 ground are this measurements normal?
thanks in advance
Tektronix
Заголовок сообщения: Re: hp omen 15-dh0003la (quanta FPC54 LA-H482P REV 1) keyboard connector messed up
Добавлено: 23 дек 2021, 10:57
Зарегистрирован: 30 авг 2017, 04:53 Наличности на руках: 5.88 Сообщения: 303 Откуда: США
There is no way to know if these are normal without either a schematic or an identical board to check against, so I can't help you with that.
Frankly, I'm not sure what you're trying to do here. Are you concerned about blown inputs on the EC or the connector not making good contact?
elgatillo263
hi yes im looking for someone who have this board post its measurements from the keyboard connector i don want to connect the keyboard and blow it too if the keyboard connector have bad pin diode values
Sashamarzor
Добавлено: 30 дек 2021, 19:43
Зарегистрирован: 18 сен 2020, 22:47 Наличности на руках: 40.05 Сообщения: 68 Откуда: Moscow
выложить четкое фото со сломанным разъемом
elgatillo263
Заголовок сообщения: Re: hp omen 15-dh0003la (quanta FPC54 LA-H482P REV 1) keyboard connector messed up [РЕШЕНО]
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 17
