Заголовок сообщения: HP Pavilion 15-p033tx (Y11A DAY11AMB6E0 Rev:E) not switch on
Добавлено: 15 дек 2020, 05:48
Зарегистрирован: 25 сен 2018, 18:24 Наличности на руках: 8.00 Сообщения: 22 Откуда: Myanmar
Model : HP Pavilion 15-p033tx Board id : Y11A DAY11AMB6E0 Rev - E
A few days ago, laptop came power on but no display. Caplocks led blinks one time and continuously. I found CMOS battery is 0V and replaced with good one. And i notice that CMOS battey is drain very fast. When I replaced 3.3V New CMOS battery and a few minutes later it has 2.9V. I found RTC_RST# is about 2.3V (low). I think C367 is leak. So i Remove C367 and laptop run normally. Boot in windows and tested all fine.
After two days, laptop is no display again. Caplocks led blinks one time and continuously again. I try to find the fault but not success. And now laptop cannot switch on. Press power button and no response. Before press power key, Q19 Pin 3 (RTC_RST#) is 2.0V and Pin 2 EC_RTC_RST is 0V. After pressing the power key, Q19 Pin 3 (RTC_RST#) is 2.5V for a second and then 0V. Pin 2 EC_RTC_RST is 3.2V.
I also try to measure the current flows of RTC battery connector using DC Power Supply and Multimeter. Amphere consumption is about 0.030 mAmp. How can i find the fault?
MoneyBot
Сообщения: 44 Откуда: localhost
MoneyBot
jocker
Заголовок сообщения: Re: HP Pavilion 15-p033tx (Y11A DAY11AMB6E0 Rev:E) not switch on
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 173
