HP 15-ay014ne (Bdl50 la-d704p ) Reset while installing os https://vlab.su/viewtopic.php?f=53&t=114628 |
nasser_pczone1 [ 19 апр 2021, 01:29 ] | |
Заголовок сообщения: | HP 15-ay014ne (Bdl50 la-d704p ) Reset while installing os |
Hi guys This laptop restart after the first loading of windows installations before "install windows" button and continues this problem This what I checked - Change ram -Bios update last version -heat the GPU -disconnect all unessery component -I tried with some another os But no success Thanks in advance |
Евгений18 [ 19 апр 2021, 12:12 ] | |
Заголовок сообщения: | Re: HP 15-ay014ne (Bdl50 la-d704p ) Reset while installing os |
Are all the CPU phases working? |
nasser_pczone1 [ 19 апр 2021, 13:06 ] | |
Евгений18 писал(а): Joined: 24 Sep 2012, 11:42 Cash on hand: 711.03 [Donate] Posts: 771 Location: г. Москва Has thanked: 30 times Have thanks: 104 times Are all the CPU phases working? Did you mean rhe pwm coil voltage? Yes that OK on about 1.2 |
Евгений18 [ 19 апр 2021, 13:17 ] | |
Measure with an oscilloscope |
nasser_pczone1 [ 19 апр 2021, 16:32 ] | |
Sorry I don't have osiliscop.. Can I try with another way? |
nasser_pczone1 [ 19 апр 2021, 21:55 ] | |
I just test the that 2 coil of pwm one of coil no voltage come out and another one has 0.9v I resold the ncp81206 but no help What I should to do Thanks in advance |
nasser_pczone1 [ 20 апр 2021, 23:18 ] | |
I think that 2 coil not for vcore only one of maybe on of that for integrated Intel GPU is that OK? |
teknikbursa [ 25 апр 2021, 00:49 ] | |
pls remove 2 coils for uma ![]() |
nasser_pczone1 [ 25 апр 2021, 19:59 ] | |
Did you test that?? |
nasser_pczone1 [ 28 апр 2021, 22:04 ] | |
i checked not success |
