Sashamarzor писал(а):
well a short circuit on the alv 3.3v and 1v coils always means the pch is dead. but to be 100% sure you can do a short test, remove the 3.3V coil and apply 3V to the low resistance pad and then see what heats up (99.99999% in this case) is pch
pch is getting warm, so its dead
thank you
