Текущее время: 15 июн 2024, 20:55
ayad
Заголовок сообщения: hp (la-d703p) no 3,5 valw Добавлено: 13 июн 2022, 16:27 |
Зарегистрирован: 11 май 2013, 10:38 Наличности на руках: 1,449.20
hi all there is no +3VALW , +5VALW because the EC_ON is 0v , i reprogrammed kb9022 nothing change , i have replaced it and nothing change you should know the laptop is charging so all signal are ok , many laptops the EC_ON are 0v , why? and how to fix it? note i connect 3 volt to pin EC_ON 3,5 are raised but nothing change
Котеус
Заголовок сообщения: Re: hp (la-d703p) no 3,5 valw Добавлено: 15 июн 2022, 09:57 |
Зарегистрирован: 19 янв 2016, 10:24 Наличности на руках: 734.00
Сообщения: 628 Откуда: Eversong
What about ldo's? 14 and 15 pins on pu2. ec_on is signal FROM pu2 (on scheme) enable signals for +3/5valw is entrip1/2, for RT8243A its from-ic signals, connected to gnd with 100k resistors (see datasheet), so if ldo's are in normal values and no shorts on +3/5valw - try to change the pu2.
and what about power key? signals on jpwr1?
