HP ProBook 6555b https://vlab.su/viewtopic.php?f=53&t=13696 |
ayad [ 06 июн 2013, 14:43 ] | |
Заголовок сообщения: | HP ProBook 6555b |
Hi all I have HP ProBook 6555b , when I press power bottom , just the charging led is flashing 8 times and stop , please any one could help me to solve that problem ......... |
joni12341 [ 06 июн 2013, 17:19 ] | |
Заголовок сообщения: | Re: HP ProBook 6555b |
The power supply work? check? tossed known working? |
ayad [ 06 июн 2013, 18:56 ] | |
How can I check power supply ? |
joni12341 [ 06 июн 2013, 21:56 ] | |
Well, for example, throw a 100% working! |
kotuk77 [ 07 июн 2013, 20:04 ] | |
Try to flash the BIOS on the programmer. |
ayad [ 08 июн 2013, 09:20 ] | |
kotuk77 писал(а): Try to flash the BIOS on the programmer. I did but nothing change ..... |
spec3202712 [ 08 июн 2013, 10:35 ] | |
ayad писал(а): Hi all I have HP ProBook 6555b , when I press power bottom , just the charging led is flashing 8 times and stop , please any one could help me to solve that problem ......... than recorded BIOS? where he took the bios file? worn-out batteries? what number of the motherboard? |
ayad [ 08 июн 2013, 10:46 ] | |
spec3202712 писал(а): ayad писал(а): Hi all I have HP ProBook 6555b , when I press power bottom , just the charging led is flashing 8 times and stop , please any one could help me to solve that problem ......... than recorded BIOS? where he took the bios file? worn-out batteries? what number of the motherboard? Hannstar MV-6 94 V-0 Posted after 4 hours 25 minutes 39 seconds: Thanks to all .......... |
spec3202712 [ 09 июн 2013, 01:45 ] | |
ayad писал(а): Hi all I have HP ProBook 6555b , when I press power bottom , just the charging led is flashing 8 times and stop , please any one could help me to solve that problem ......... than recorded BIOS? where he took the bios file? worn-out batteries? |
chulat [ 09 июн 2013, 02:41 ] | |
ayad писал(а): Hannstar MV-6 94 V-0 This is no Main Board Look there - http://vlab.pp.ru/viewtopic.php?f=35&t=2206 |
