Заголовок сообщения: hp dv 6625el (da0at3mb8f0 rev F) turns off immediately, after 2 seconds
Добавлено: 19 июл 2013, 12:51
Зарегистрирован: 17 сен 2012, 11:07 Наличности на руках: 1.09 Сообщения: 42 Откуда: italy
The laptop turns off immediately. All LEDs light up and then go off The battery is charged I did not detect any short with bench power supply absorbs up to 0.35 A, and then turns off I changed the ram, the CPU I did reset the cmos
Thanks
RsM
Заголовок сообщения: Re: hp dv 6625el (da0at3mb8f0 rev F) turns off immediately, after 2 seconds
Добавлено: 19 июл 2013, 21:25
Зарегистрирован: 12 окт 2012, 21:53 Наличности на руках: 5,128.83 Сообщения: 8294 Откуда: Сыктывкар
You need to check all voltages. Some of them are absent.
roby123
Добавлено: 22 июл 2013, 00:03
Which voltages Where do I start? Vin, +5 V, +3 V......
Thanks
RsM
Добавлено: 22 июл 2013, 09:49
yes, and so on. On inductors. Look at sch and you will see it.
