Текущее время: 21 ноя 2026, 04:22
 Заголовок сообщения: LA-E801P REV 2.0 (HP 260 G6 TPN-C129) MISSING VCC_GT
СообщениеДобавлено: 04 июл 2025, 19:27
Hi Everyone.
This modell does not have a dedicated GPU chip only the CPU integrated.
I have backlight after start but no POST obviously.
EC firmware is fine and I have tryed a lot of BIOS versions.
Once I had VCC_GT but no picture still, but now I cant get it to work. No VCC_GT.
Any Idea?
 Заголовок сообщения: Re: LA-E801P REV 2.0 (HP 260 G6 TPN-C129) MISSING VCC_GT
СообщениеДобавлено: 05 июл 2025, 08:58
More infó: The Original BIOS was BID 08328
СообщениеДобавлено: 05 июл 2025, 12:58
Missing smd components, dead cpu, wrong firmware BID, broken LCD cable.
VCC_GT not necessarily for POST, it can turns on with gpu load only.
СообщениеДобавлено: 05 июл 2025, 19:22
+ I think I can rule out bad firmware BID because with all other BIOS BID laptop does not even start and only consumes 31Millamps
+ Broken LCD cable can be ruled out because external keyboard does not have CAPS LOCK reaction.
Leaves me with CPU or missing component ...
If noone has idea then i'm gona assume that since PLTRST other signals ar ok then CPU is faulty
and when I have almost given up...my ram tester arrived and guess what 2 datalines are missing. so either soldering in ram or cracked solder balls under CPU
 Заголовок сообщения: Re: LA-E801P REV 2.0 (HP 260 G6 TPN-C129) MISSING VCC_GT  [РЕШЕНО]
СообщениеДобавлено: 06 июл 2025, 21:35
Both ram testers shows missing two line in the same place and chekced that no problem with the slot soldering.
These two lines on both RAM are near each other at the same place under the CPU cracked soldering bal are likely.
В этой теме нет новых непрочитанных сообщений. c129 (la-e791p) не могу определить шим контроллер
anssinlc
17 фев 2019, 06:38
ZZZ7ZZZ Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 250 G6 ( la-e801p rev 2.0) После прошивки bios с сайта перестал работать кулер
max1052
13 дек 2018, 14:39
В этой теме нет новых непрочитанных сообщений. HP 15t-bs000 (CSL50/CSL52 LA-E801P Rev 2.0) Нет дежурного напряжение в цепи питание
Macintosh_RK
15 май 2019, 00:32
acelectric Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 15-bs017ur (LA-E801P Rev.:2.0) Нет подсветки
iinnjj
30 окт 2019, 12:11
ivans Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 15-bs019ur (CKL50 LA-E801P rev:1.0) Какие транзисторы стояли
saa
13 май 2021, 10:00
saa Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 126
