HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing https://vlab.su/viewtopic.php?f=53&t=25453 |
abuholm [ 18 окт 2014, 00:23 ] | |
Заголовок сообщения: | HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing |
Hi everyone, this old laptop came to me with password [stringent security] issue and after swapping bios chip, password was removed and I found out the South-bridge needed re-balling [smart-card error issue]. After re-balling, laptop charging led blinks six times and then restarts. I want to know if anyone has encountered this issue and how it was solved. I suspect South-bridge but i want confirmation... ![]() |
MSF113 [ 18 окт 2014, 10:22 ] | |
Заголовок сообщения: | Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing |
6 Caps Lock/Num Lock BIOS BIOS authentication failure |
abuholm [ 18 окт 2014, 12:50 ] | |
MSF113 писал(а): 6 Caps Lock/Num Lock BIOS BIOS authentication failure Thanks for the reply but in this case it is the charging Indicator (orange led) that is blinking.. |
MSF113 [ 18 окт 2014, 13:06 ] | |
I don't see what charging LED blinking, sorry. charging LED blinking - problem with Power. |
abuholm [ 18 окт 2014, 19:55 ] | |
MSF113 писал(а): I don't see what charging LED blinking, sorry. charging LED blinking - problem with Power. I totally agree with you that it is a power issue because I just realized that there is no voltage on coil L29 [+VCCP] and L26 [+VCC_CORE], but everything was okay before the re-balling.All components around the South-bridge are okay. I will like to know if there are some signals I can check to verify whether the problem is from South-bridge or elsewhere. |
abuholm [ 25 окт 2014, 05:34 ] | |
Заголовок сообщения: | Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing [РЕШЕНО] |
Hi everyone, after going through a lot of ordeal due to the client threatening me to either fix the motherboard or replace the laptop... ![]() ![]() |
