Lotse писал(а):
На 13 EN и 18 ENC стабильно высокие уровни
Какие именно?
Channel 1 Enable and Current Limit Setting Input. Connect a resistor to GND to
set the threshold for channel 1 synchronous RDS(ON) sense. The GND − PHASE1
current limit threshold is 1/10th the voltage seen at ENTRIP1 over a 0.515V to 3V
range. There is an internal 10μA current source from VREG5 to ENTRIP1. Leave
ENTRIP1 floating or drive it above 4.5V to shut down channel 1.
