https://vlab.su/
HP 15-e016tu (DAR62CMB6A0) 2 CAPS LOCK BLINKS
https://vlab.su/viewtopic.php?f=53&t=57379
Страница 1 из 1
kandyan [ 17 фев 2017, 23:03 ]
Заголовок сообщения:  HP 15-e016tu (DAR62CMB6A0) 2 CAPS LOCK BLINKS
This laptop came with no power but charging LED on when charger plugged in and I did following steps to repair it.
01. Reball chipset BD82HM76
---> Laptop turn on / no display / caps lock 2 blinks
02. BIOS flashed/programmed (U15 25Q80BSIG / U31 cfeon Q32B-104HIP)
---> Laptop turn on / no display / caps lock 2 blinks (flash/programmed different types 04 time but same error)
03. Replace new BD82HM76
04. Reball CPU
After laptop turned on CPU gets hot / HM76 gets hot (working) but no display with 2 blinks on caps lock.
What's the reason?
(Oscilloscope shows BIOS reading properly)
Rein [ 22 фев 2017, 02:55 ]
Заголовок сообщения:  Re: HP 15-e016tu (DAR62CMB6A0) 2 CAPS LOCK BLINKS
05. Replace CPU
soscomputer2008 [ 12 апр 2017, 10:41 ]
cpu i3, i5 are often dying
Boglen [ 12 апр 2017, 16:49 ]
did you flash bios?
Be nice if you plug post card and look at post codes.
aleksandr [ 12 апр 2017, 17:01 ]
Replace new flash
http://www.phpbb.com/
