https://vlab.su/
HP15-p189sa (DAY11AMB6E0) NO power up
https://vlab.su/viewtopic.php?f=53&t=64891
Страница 1 из 1
scobay [ 17 авг 2017, 23:49 ]
Заголовок сообщения:  HP15-p189sa (DAY11AMB6E0) NO power up
Im working on this board day11amb6e0. On the KBC Im gettting
RSMRST# 3.3v then to 0v immediately
S5_ON 3.3v then 0v immediately.
No +3v to KBC
Mainon stays at 0v
Also theres no +5vs5 or +3vs5
PU11
vin is ok
+3vpcu is ok +3v
S5_on 3.3v then 0v immediately
Pgood 0v
En2 4.5v
PU12
+5VPCU ok 5v
pgood 0v.
What would cause the S5_on to drop to 0v ?
When S5_on is 3.3v then I get +5VS5 and +3VS5 for a couple of seconds then both drop to 0v because s5_on goes low.
scobay [ 19 авг 2017, 03:02 ]
Заголовок сообщения:  Re: HP15-p189sa (DAY11AMB6E0) NO power up
Any ideas?
scobay [ 29 авг 2017, 14:22 ]
Still struggling with this, any input appreciated.
vldmrdnpr [ 29 авг 2017, 15:11 ]
ec_wrst#, acin, lid_ec#, ad_id, ad_type, 3v_rtc, rtc_clock_32768 ?
scobay [ 29 авг 2017, 17:28 ]
ec_wrst =3.3v
Acin = 3v
Lid_ec# = 3.3v
ad_id = .6v
ad_type = .6v
3v_rtc = 2.7v
rtc_clock_32768 not on this board
Posted after 2 minutes 56 seconds:
A block diagram or signal order of Haswell chip would be helpful. Im getting S5_on which is generating +3vs5 and +5vs5 for a second or so when the power button is pressed then s5_on drops to 0v
scobay [ 30 авг 2017, 12:57 ]
CN9
Pin 1 =3v drop to 0v
Pin 2 =0v
Pin 3 =1.28v
Pin 4 =0v
Pin 5=0v
Pin 6=0v
Pin 7=3.3v drops to 0v quickly
Pin 9=0v
Pin 11= 3.3v then drop to 0v
Pin 13=0v
Pin 15=0v
http://www.phpbb.com/
