HP Pavilion 13 x360 (DA0Y61MB6E0) lcd problem https://vlab.su/viewtopic.php?f=53&t=79724 |
andromedax [ 26 авг 2018, 19:54 ] | |
Заголовок сообщения: | HP Pavilion 13 x360 (DA0Y61MB6E0) lcd problem |
Hi there, I'm looking for EDID data file for lcd led Samsung LTN133AT16. (having data corruption) HP Pavilion 13 x360 PC (DA0Y61MB6E0) having back-light, but no image. Attached the corrupted file, only for test. Thanks in advance. Вложение: LTN133AT16.7z
IOD [ 26 авг 2018, 21:03 ] | |
Заголовок сообщения: | Re: HP Pavilion 13 x360 (DA0Y61MB6E0) lcd problem |
Describe in more detail your problem. Why did you decide that the problem is in the EDID firmware? |
andromedax [ 26 авг 2018, 21:40 ] | |
IOD писал(а): Describe in more detail your problem. Why did you decide that the problem is in the EDID firmware? It works with another lcd display, (a 15 inch one) but first I changed RTD2136N chip, because it was very hot. (****) The data read from edid memory seems corrupted, compared with other data from other lcd screens. (****) Someone else has been working this motherboard before. |
Line_power1 [ 27 авг 2018, 01:26 ] | |
here is the firmware. |
