I need some help on this board.. This board when i push the start button turn on and off in 1 sec and start booting!!
When i remove the PAD6404 and PAD6400 the board start normally.. But i don't get the +VTT !! i already replace a Processor, PCH, U6400 (TPS51218DSCR).. And no changes..
Anyone have one problem like that??
Thank you
recordsman
Заголовок сообщения: Re: toshiba l650 (6050A2332301 MB 002) On and Off when push the button
hi there Porto, you must to chek +VBAT for short on ground and also try to change Q6001 FDMC8884 Q6002 AM4410NC Q6005 AM4825P_AP it's tipical also analogs of parts is: FDMC8884: AON7408L AM4410NC: DMN3030LSS AM4825P_AP: AO4455.
_________________ не будьте дампоепами... Жопа - это есть абсолютно универсальный интерфейс. Ибо через жопу можно сделать абсолютно всё!
SpinNNN
i check + VBAT in diode mode and i have 450v!! i already replace q6001 and q6002 and same issue!! But the board without q6001 and q6002 start's well and don't go off!!
could be U6603 (TPS51621RHAR) ??
recordsman
wow 1st time i see this voltage level. TPS51621RHAR yeap will try because this one control battery rail. after change this controller try do not on buttery for shure... if it's ok try to pull on battery inside
SpinNNN
Сейчас этот форум просматривают: Barabulka и гости: 32
