Текущее время: 18 апр 2024, 19:42
 Заголовок сообщения: Toshiba (VGFT MB Rev 2.1) No initialization
СообщениеДобавлено: 27 фев 2022, 03:49
Hello friends,
this board came dead with no signs of life, diagnosis reveals a shorted IT8587E-EXA, shorted u5202 (G547E1P81U), dead u8100 (TPS51225C) with some bad traces around it..
replaced IT8587E-EXA with FXA and programed, G547E1P81U replaced with uP7534A15, bad traces was restored and new TPS51225C installed, both BIOS chips flashed
now the board came to life with autostart, all voltages rises except +VGFX_CORE at L8001 and there's no init
resistance at L8001 = 3.5 ohm, L8000 = 4.6 ohm
injected 0.7v/2A in L8001 for checking, the consumption is 0.345mA
the board does not respond to the power button and autostarts, new cmos battery installed, checked D2001, replaced X2001 & X2103 doesn't help
restoring the original backed up EC dump leads to a cyclic start
where to dig ?
Edit: SYS_PWROK = 3.3v
 Заголовок сообщения: Re: Toshiba (VGFT MB Rev 2.1) No initialization
СообщениеДобавлено: 02 мар 2022, 00:14
Edit:
The backed-up PCH dump leads to a cyclic start not the EC, I've edited the dump and it looks like it's corrupted
Update:
While missing around with the bioses, I've edited and compared the downloaded dump from the site with my back-up and found that the downloaded bios from here download/file.php?id=90203 and kbc firmware from here download/file.php?id=108383 has the model number (P55-A PSPMEU-00G002) while my back-up has the same model printed on the chassis (S50-A PSKJSU-00P008) so I've cut & flashed kbc firmware from my back-up and got the official v1.3 bios from toshiba, cut it to 2 pieces (main/pch), cleared the ME and flashed all of them but situation doesn't change..
Autostart and no init and no response to the button
sounds stupid but I've tried to flash VGFTG's bios instead of VGFT, the behavior changed, no autostart and there's a response to the button but ofcurse CPU/RAM voltages doesn't rise and so no init..
I'll post my backed-up dumps and the v1.3 that I've cut from official bios, hope someone could check and fix them
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba P55-A5200 (VGFT MB rev:2.1) Прошивка IT8587e-exs
в форуме Toshiba
vovkawww
17 май 2018, 23:24
vovkawww Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DV6-3127DX (DA0LX6MB6H1 Rev H UMA) No image, long initialization
mohammedsf
05 май 2021, 03:57
mohammedsf Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell Inspiron 15-7577 P72F001 (LA-E992P Rev 2.0) No Initialization, possible dead GPU
в форуме Dell
mohammedsf
25 янв 2023, 08:07
В этой теме нет новых непрочитанных сообщений. Acer Aspire 5336-2283 (PEW72 LA-6631P) No Initialization
abuholm
06 мар 2015, 00:28
abuholm Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. 2234 - HECI error during initialization
kbdan52
04 дек 2018, 07:57
blackbj Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 7
