Do the short test which laboratory power supply. Put 1.05v to pad 1 pl802 set current to 400mA, touch your hand mainboard to see whats hot, if you cant feel temperature pull up current 100mA until you feel hot broken element, dont pull up voltage, only current.
There is good solution how to do it.
https://www.elvikom.pl/szkolenie-nr-1-p ... -t986.html
