Текущее время: 23 май 2024, 08:44
 Заголовок сообщения: SONY VAIO SVF15A (GD6 DA0GD6MB8E0 Rev E ) Need help from experienced member, heavy problem.
СообщениеДобавлено: 07 фев 2018, 00:46
Hi, i need a help from an experienced member.
Laptop starts, works but has a random shutdown every 20-30 minutes.
As soon as i disassebled it, i saw that one of the USB was broken, pins shorted. i have removed the USB and tried to install windows, laptop shutdown after 20-30 mins anyways.
i have soldered another USB and then laptop started turning off every 2 minutes . every time it could be start again. figgured out that it must have been this usb that has shorted some region in HM chipset so i have removed HM chipset and resoldered another one. THIS DID NOT SOLVE THE PROBLEM. laptop again shutdown after 2 mins, i have removed usb and removed inductors and capacitors next to other USB 3.0 x2 and USB 2.0
now again it shuts down after 20-30 mins.
i do not know what is the fail, every voltage is good , there is no liquid damage and HM is new.
Im trying to flash new BIOS ( this is model with i7-3535 cpu and nvidia 740m graphics ) i have tried to run laptop both on integrated cpu graphics and on discrete , again same stuff happening.
 Заголовок сообщения: Re: SONY VAIO SVF15A (GD6 DA0GD6MB8E0 Rev E ) Need help from experienced member, heavy problem.
СообщениеДобавлено: 07 фев 2018, 12:02
try to write bios with clean ME region, it look like the problem with it.
Многие вещи нам непонятны не потому, что наши понятия слабы; но потому, что сии вещи не входят в круг наших понятий.
СообщениеДобавлено: 10 фев 2018, 16:01
thank you, already solved with a new bios.
if anyone has the same problem, do not change HM chip, try to flash BIOS first. Would not have changed HM if the USB was not broken. Lesson learned :)
Спасибо, мои русские братья
Posted after 4 hours 20 minutes 2 seconds:
Also, forgot to mention, U24 was also faulty, replaced with an older model, works fine.
you can lock this. thanks. SOLVED
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony VAIO SVF15A (Quanta GD6) отключается через 1 мин. 50 сек.
в форуме Sony
2N3904
2700
27 дек 2016, 19:33
В этой теме нет новых непрочитанных сообщений. Sony VAIO SVF15A (Quanta GD6) отключается через 1 мин. 50 сек.
в форуме Sony
xikmat
26 янв 2021, 13:31
xikmat Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. SVF15A (DA0GD6MB8E0) Название микросхемы
в форуме Sony
max33
02 мар 2017, 18:39
max33 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenvo l520 (please help me i need bin lenvo l520) please help me i need bin lenvo l520
issabaouch
10 ноя 2017, 02:06
В этой теме нет новых непрочитанных сообщений. SONY SVF15A новый вентилятор для ноутбука UDQF2ZR77CQU
jianghongb
25 май 2021, 10:46
jianghongb Перейти к последнему сообщению
Сейчас этот форум просматривают: Majestic-12 [Bot] и гости: 7
