Текущее время: 06 июн 2024, 11:28
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 13 июн 2015, 22:15 |
Сообщения: 262 Откуда: Alicante, Spain
Measure and post voltages from all pins of Q10. Вложение: Q10.jpg
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 14 июн 2015, 22:29 |
pkurls писал(а): drain have 19v And without battery? Sorry I wanted to say without Charger.
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 15 июн 2015, 13:43 |
andromedax писал(а): Measure voltage in drain of Q13 (VINT20) (with and without charger) It is very important to know the value of VINT20 without charger.
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 15 июн 2015, 15:35 |
pkurls писал(а): Without charger give 9v and after plug the charger its give 19v It seems low voltage from battery. Bad battery? How many volts is it rated? (check it in battery label)
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 15 июн 2015, 19:17 |
pkurls писал(а): battery is working on my working laptop thats problem in mainboard Q10 has 11.7 volts in its drain, and is connected to the source of Q13. If Q13 has 11.7 volts in its source, and 9 volts in its drain, (VINT20) then the internal diode are damaged, and mosfet Q13 seems not being saturated, so replace it whit a new one, or an equivalent. Вложение: Si4890DY.jpg
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 23 июн 2015, 12:15 |
pkurls писал(а): i have changed but have same problem Do you get same voltage measurements as before? Something don't match.
andromedax
Заголовок сообщения: Re: lenovo t61p (T61p) Charging problem Добавлено: 23 июн 2015, 19:26 |
pkurls писал(а): i changed q13 q10 all have same condition Battery must have 10.8V, I'm not sure only 9 volts will be enough. Вложение: LTPIB049.jpg
