Start by checking the short circuit in the circuit on the chokes. Then go to the chip "Charger" check its signals) it forms 19 V on the Board after the transition to the chokes on duty power, look at them voltage 3.3 and 5 V, 1.2 V, 1 V, well, everything that feeds the processor, video, RAM. If not see the signals for the PWM controllers, the main is En which goes with the cartoon. If everything is then try to change the Bios and Ec))) good Luck!
---------- Добавлено спустя 2 минуты 19 секунд: ---------- Ах да! Чуть не забыл) Еще на кнопке включения питание проверь)
---------- Добавлено спустя 37 секунд: ---------- Oh yeah! I almost forgot) is Still on the button on the power check)
