Привет всем!проблема с буком, изначально бук пришел с дырой в мульте IT8226E из-за кривой пайки разъема коротнули центровой с +.
заказали мульт и разъем питания, программатор определяет его как 8176 и очищает его с ошибками:
прошивку нашел только тут
viewtopic.php?f=58&t=114799&p=862885&hilit=%2Anm+c372%2A#p862885Check connection ...
Received ITE ID -> 8176 rev -> 01
INIT complete.
ERASE ...
There may be a problem with the block:
From ADR: 0E000h to 0E400h [FE (FCh)]
From ADR: 0E400h to 0E800h [FE (FCh)]
From ADR: 0E800h to 0EC00h [FE (FCh)]
From ADR: 0EC00h to 0F000h [FE (FCh)]
From ADR: 0F000h to 0F400h [FE (FCh)]
From ADR: 0F400h to 0F800h [FE (FCh)]
From ADR: 0F800h to 0FC00h [FE (FCh)]
From ADR: 0FC00h to 10000h [FE (FCh)]
From ADR: 1E000h to 1E400h [FE (FCh)]
From ADR: 1E400h to 1E800h [FE (FCh)]
From ADR: 1E800h to 1EC00h [FE (FCh)]
From ADR: 1EC00h to 1F000h [FE (FCh)]
From ADR: 1F000h to 1F400h [FE (FCh)]
From ADR: 1F400h to 1F800h [FE (FCh)]
From ADR: 1F800h to 1FC00h [FE (FCh)]
From ADR: 1FC00h to 20000h [FE (FCh)]
ERASE complete.
The number of bytes value of FFh -> 48671
Writing, please wait ... complete.
Verify ... complete.
ноутбук включается пишет the connected ac adapter has a lower wattage than the recommended which was shipped with the system. to use ac power, please connect the ac adapter which was shipped with the system.
АКБ нет заряда, т.е. бук не видет зарядку зарядка родная 170W
вопрос мульт бракованный прислали?
