Hello,
this board NM-B453 came from a previously failed repair attempt with no power, quick inspection shows a dead PQ311 & PQ312, wrong SPI ROM used (GD25LB64 1.8v) and a capacitor installed in PR1007 !!
replaced PQ312 and PQ311 (used AON6414), according to the schematic replaced SPI ROM with W25Q64JV 3.3v and removed the capacitor installed on PR1007, flashed with official BIOS (81BT)..
the board came to life, all powers raised except +VCC_GT @ PL1001 = 0v and no initialization
another quick inspection shows the lack of CPU_DRAMRST# = 0.04v, cutting RC23 raised CPU_DRAMRST# to 1.2v but still no init..
onboard RAM disabled using the straps SO-DIMM Only RC1631 RC1632 (not so sure if correct)
remade to UMA using straps RC1609 to RC1610 & RC1608 to RC1558 and removing PL1401 & PL2401 (also not so sure if correct)
still no CPU_DRAMRST# and no init
made all measurements:
GPU+3VGS = 3.3v
+1.8VGS = 1.75v
+1.35VGS = 1.33v
+0.95VGS = 0.99v
+VGA_CORE PL2401 = 0.88v
+1.35V_LX PL1401 = 1.33v
CPU+VCC_GT PL1001 = 0v
+CPU_CORE PL1002 & PL1003 = 0.89v
+VCCSA PL1004 = 0.9v
+2.5V_DDR = 2.47v
+0.6VS = 0.58v
+1.8VALW = 1.76v
+1.0VALW = 0.99v
Signals:CPU_DRAMRST# = 0.04v
VCCST_PWRGD = 1v
CPU_PROCPWRGD = 1v
SYS_PWROK = 3.3v
PCH_PWROK = 3.3v
EC_RSMRST# = PCH_DPWROK_R = PCH_RSMRST#_R = 3.3v
EC_VCCST_PWRGD = 1v
DGPU_PWROK = VR_VGA_PWRGD = 3.3v
PLT_RST# = 3.3v
SUSACK# = 2.5v
LID_SW# = 3.3v
PM_SLP_S3# = 3.3v
PM_SLP_S4# = 3.3v
SYSON = 3.3v
SUSP# = 3.3v
are these normal ?
VGA_PWROK = 0.24v ?
GPU_RST# = 0v ?
PXS_RST# = 0v ?
+1.05VGS_B_PG = 0v (signal doesn't go anywhere)
+1.0VALW_PG = 0v (signal doesn't go anywhere)
ALW_PWRGD = 0v (signal doesn't go anywhere)
+3V_PWRGD = 0v (signal doesn't go anywhere)
by removing SPI ROM, all CPU phases PL1001 & PL1002 & PL1003 rises to 1.1v something
the wrong capacitor installed in RC1007 made me suspect the phases of the CPU, removed PL1002 & PL1003 and tested from PWM side, 1.1v @ PL1003 but 5.7v @ PL1002
traced it to PWM signals on PU901 (NCP81218M), pin 17 PWM2_2PH = 1.8v while pin 16 PWM1_2PH = 0.24v is that normal or PU901 is dead ??
