Текущее время: 13 ноя 2026, 14:01
 Заголовок сообщения: lenovo IdeaPad3 14 (BTUU1 NM-A381 REV: 1.0) laptop and will not power on and or charge
СообщениеДобавлено: 12 сен 2024, 03:04
Hi all,
i have an lenovo yoga 3.14 (80jh) laptop and will not power on and or charge, measured the battery voltage 0.00v dead flat.
checked for shorts not see anything, checked mosfets, fuses and caps around battery and input. ive missed something i managed to charged the battery, once charged placed the battery back into the laptop and powered up.
i wasn't getting negotiating voltage 19v only 5v. so i replaced the pu101 (BQ24715RGRR), once replaced i was getting negotiating voltage 19v but blinking white light 3sec interval. battery was charging until, mosfets PQ301, PQ302 both went up in smoke as well as PU301 (TPS51716RUKR) was so hot to touch. replaced all components. battery had some charge laptop came back to life.
i have replaced the battery as it was degrading and tried another powerpack, still have the original issue.
I'm an extreme newbie to smd electronics and electronic in general. but willing to learn.
Any guidance will be appreciated.
Oyama
 Заголовок сообщения: Re: lenovo (3.14) laptop and will not power on and or charge
СообщениеДобавлено: 12 сен 2024, 10:46
When creating a topic, you need to specify the motherboard model.
СообщениеДобавлено: 12 сен 2024, 11:09
My apologies
Mainboard model: BTUU1 NM-A381 REV: 1.0
 Заголовок сообщения: Re: lenovo IdeaPad3 14 (BTUU1 NM-A381 REV: 1.0) laptop and will not power on and or charge
СообщениеДобавлено: 16 сен 2024, 04:10
Update...
i removed the new battery, and charging cable pressed and held the power button for about 60sec. plugged the charger laptop came alive.
fasten the mb back into the laptop everything was working perfectly until i opened the laptop screen further, power then when off then closed the screen a bit pressed the PB came back again. maybe a dry joint or a crack on the board. spent over 2hrs cannot fined a thing. any suggestions
СообщениеДобавлено: 26 сен 2024, 06:31
i have found one issue pl201 was extremely hot to touch, around the area i was opening and closing the laptop lid.
once stocks arrive will post my result fingers crossed
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. LENOVO YOGA 3 (btuu1 nm-a381 rev:1.0) ищу схему
senseyoo7
14
7273
21 мар 2020, 18:58
guar33 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. need equivalent of R14WA (lenovo yoga 3 (btuu1 nm-a381 rev:1.0) ) need equivalent of R14WA
mohamedxp2
10 фев 2018, 01:28
mohamedxp2 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo Yoga 3 14 (80jh) (BTUU1 NM-A381 rev 1.0) нет инициализации, пост код F3
dimon_105
31 окт 2019, 09:20
valek_ Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. LENOVO YOGA 3 (btuu1 nm-a381 rev:1.0) Не стартует
Туманный Тушканчик
21 ноя 2020, 18:10
Туманный Тушканчик Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo yoga 3 (BTUU1 NM-A381) не включается, подозрительный свист в районе дежурки 3в
virus.tmn
16 май 2019, 18:20
virus.tmn Перейти к последнему сообщению
Сейчас этот форум просматривают: antonP, DaveGibson и гости: 66
