lenovo IdeaPad3 14 (BTUU1 NM-A381 REV: 1.0) laptop and will not power on and or charge https://vlab.su/viewtopic.php?f=58&t=144257 |
Oyama65 [ 12 сен 2024, 04:04 ] | |
Заголовок сообщения: | lenovo IdeaPad3 14 (BTUU1 NM-A381 REV: 1.0) laptop and will not power on and or charge |
Hi all, i have an lenovo yoga 3.14 (80jh) laptop and will not power on and or charge, measured the battery voltage 0.00v dead flat. checked for shorts not see anything, checked mosfets, fuses and caps around battery and input. ive missed something i managed to charged the battery, once charged placed the battery back into the laptop and powered up. i wasn't getting negotiating voltage 19v only 5v. so i replaced the pu101 (BQ24715RGRR), once replaced i was getting negotiating voltage 19v but blinking white light 3sec interval. battery was charging until, mosfets PQ301, PQ302 both went up in smoke as well as PU301 (TPS51716RUKR) was so hot to touch. replaced all components. battery had some charge laptop came back to life. i have replaced the battery as it was degrading and tried another powerpack, still have the original issue. I'm an extreme newbie to smd electronics and electronic in general. but willing to learn. Any guidance will be appreciated. Oyama |
Serguz05 [ 12 сен 2024, 11:46 ] | |
Заголовок сообщения: | Re: lenovo (3.14) laptop and will not power on and or charge |
When creating a topic, you need to specify the motherboard model. |
Oyama65 [ 12 сен 2024, 12:09 ] | |
My apologies Mainboard model: BTUU1 NM-A381 REV: 1.0 |
Oyama65 [ 16 сен 2024, 05:10 ] | |
Заголовок сообщения: | Re: lenovo IdeaPad3 14 (BTUU1 NM-A381 REV: 1.0) laptop and will not power on and or charge |
Update... i removed the new battery, and charging cable pressed and held the power button for about 60sec. plugged the charger laptop came alive. fasten the mb back into the laptop everything was working perfectly until i opened the laptop screen further, power then when off then closed the screen a bit pressed the PB came back again. maybe a dry joint or a crack on the board. spent over 2hrs cannot fined a thing. any suggestions |
