Hello..
this board came with a broken dc_jack, shorted Adapter_ID to 20v
half of the board was dead... here are some of the replaced parts:
EC chip IT8226E-192
PCH
PU201 (BQ780s)
PU601 (installed TPS51225C instead of original RT6585B)
PU7501 (NCP81611)
UC3 (SPI Rom)
PD203 (Adapter_ID protection diode)
PQ201 & PQ202
Some shorted capacitors here & there...
EC flashed, Clean-me bios flashed....
the board started and have image for a couple of seconds then went dead, a short in 5valw and the new PU7501 chip was dead..
replaced it for the second time and the board started a couple of seconds then dead again, PU7501 found dead !!
my fault... damn burned PR7505 2.2ohm resistor was the culprit.. i replaced the chip & the resistor and the board started
everything was so beautiful, clean windows & drivers installed, programs installed... cpu benchmarks for thermal testing...
the system was running for hours, i was about to give it to the customer till i started furmark for gpu testing...
in less than a minute the image went out (backlight still on) for seconds and back on, goes again off and back on, till i stop the gpu load...
I suspect a weak or non-working gpu power chip (ncp303150), decided to replace all 3 along with vram power with new chips, ncp303150 wasn't available, installed QD9619A instead with some mods but they didn't start, tried with ncp303160 and they didn't start too..
got the original ncp303150 and installed 3 new chips and they started... full initialization and image appears then the fans go to full speed then the board shuts down..
I've measured the time and it's 32 seconds.... windows fully loads in that time with no errors !
checked the whole board again and found boiling hot U4 pd (RTS5455) i removed it but i don't have a replacement for now...
nothing changed, 32 seconds then off...
EC & Bios flashed again, ncp303150 chips replaced again, thermal sensors U1 & U134 replaced... no change
when powering with a cleared rtc the board resets normally with fans off, when it get a full initialization and the image appears it shuts off immediately... it's like the 32 seconds start counting from the button press but they are enough to finish the resets and have initialization.... after that when pressing the button again initialization needs 2 seconds and the image appears then fans go 100% speed then turn off after 30 seconds...
tried to convert to uma by disconnecting gpu power and (with/without uma bios) but there is no initialization...
any suggestions ??
should it work without the pd controller U4, could it be the culprit ?
could it convert to uma to check the gpu ?
please help...
