acer 551g (da0zrpmb6c0) no video on screen https://vlab.su/viewtopic.php?f=59&t=109587 |
bokin021 [ 28 ноя 2020, 17:35 ] | |
Заголовок сообщения: | acer 551g (da0zrpmb6c0) no video on screen |
i did uma but video only on vga i mesure lvds cable all voltage are ok vdd, lvds, en backlight, edid etc ..I change new screen also lvds cable ..Please help. |
hunter_nick [ 28 ноя 2020, 19:26 ] | |
Заголовок сообщения: | Re: acer 551g (da0zrpmb6c0) no video on screen |
R509 on R526 so did? viewtopic.php?f=59&t=64946 |
bokin021 [ 28 ноя 2020, 19:29 ] | |
I did same.. |
hunter_nick [ 28 ноя 2020, 19:46 ] | |
Is there a picture on vga? Are the matrix cable and matrix working? power supply to the matrix come? Discrete video is not in the operating system? |
bokin021 [ 28 ноя 2020, 20:01 ] | |
Everthing working only not working with lvds cable..All voltage are ok.. |
hunter_nick [ 28 ноя 2020, 20:10 ] | |
19 and Is there 3.3 on the matrix? |
bokin021 [ 28 ноя 2020, 20:27 ] | |
Yes 19 v vdd 3.3.en backlight edid 3.3v etc |
bokin021 [ 30 ноя 2020, 15:33 ] | |
what signal I shold test more? |
bokin021 [ 14 дек 2020, 18:44 ] | |
now does not swich on at all only blink ones diode..I change multicontroler new bios but same doing.. |
bokin021 [ 29 дек 2020, 22:01 ] | |
Please help i turn on motherboard on vga pictures but again no back light also vcc 0v 19v and edid 3.3v ..I check signal back light on also 0v..What more i should check? |
Ciber SLasH [ 29 дек 2020, 22:45 ] | |
Check/replace L35. |
bokin021 [ 30 дек 2020, 00:13 ] | |
I did before..Coil is fine.. |
bokin021 [ 30 дек 2020, 16:45 ] | |
i have check travis anx 3111 bl on 0v ,travis rst # 3.2v , digon 0v , all rest voltage is ok avddr 3.3v int lvds 3.3v..i also replace new one bu same.. |
