Acer 5920 (DA0ZD1MB6G0 rev:G) LED FLASHER PANEL https://vlab.su/viewtopic.php?f=59&t=15641 |
eletmoraes [ 17 сен 2013, 18:02 ] | |
Заголовок сообщения: | Acer 5920 (DA0ZD1MB6G0 rev:G) LED FLASHER PANEL |
the LED flashes at the beginning of the panel, right after Windows loads briefly then immediately turn off the Notebook completely getting only the LED battery lights. |
RsM [ 17 сен 2013, 20:28 ] | |
Заголовок сообщения: | Re: Acer 5920 (DA0ZD1MB6G0 rev:G) LED FLASHER PANEL |
Update BIOS, look for water. |
eletmoraes [ 19 сен 2013, 00:45 ] | |
Заголовок сообщения: | Re: Acer 5920 (DA0ZD1MB6G0 rev:G) LED FLASHER PANEL [РЕШЕНО] [РЕШЕНО] |
By connecting realize roughly 5 blink of led panel, after Windows loads and before you finish charging the system shuts down the notebook. I removed the modem card conexant and turn, I notice that the notebook no longer flashes the LEDs panel as before. The other problem we had (reboot windows) was damaged operating system. |
