https://vlab.su/
Acer Aspire 5733Z (LA-6582P) Turns off after 5 minutes
https://vlab.su/viewtopic.php?f=59&t=17557
Страница 1 из 1
brogdan [ 09 дек 2013, 16:42 ]
Заголовок сообщения:  Acer Aspire 5733Z (LA-6582P) Turns off after 5 minutes
hello
i have an Acer Aspire 5733Z that turns off after exactly 5 minutes after pushing the power on button.
it dose not overheat, so please no posts regarding cleaning the cooling system.
what i have don until now:
Flashed 3 versions of different BIOS + EC
changed the BD82HM55 with new one
tried with different CPU
Changed osscilators Y1,Y2,Y6 and X1
Any other ideas?
thank you
RsM [ 09 дек 2013, 22:28 ]
Заголовок сообщения:  Re: Acer Aspire 5733Z (LA-6582P) Turns off after 5 minutes
dump or clear ME?
brogdan [ 09 дек 2013, 22:42 ]
What do you mean? Do you want me to read the bios and ec and post here the dump?
I don't understand. Sorry. How to clear ME?
RsM [ 09 дек 2013, 23:14 ]
ok. remove RTC battery and Flash bios from mail. After connect RTC battery.
brogdan [ 10 дек 2013, 00:38 ]
thank you very much. i will try this first thing in the morning and post the result!
brogdan [ 10 дек 2013, 13:51 ]
thank you again. it worked like a charm.
just for me to understand...after first boot it writes some data on the EC rom?
is there any way to manually clear the ME, if i have a previously read EC rom?
RsM [ 10 дек 2013, 14:18 ]
https://vlab.su/viewtopic.php?f=181&t=6897
https://vlab.su/viewtopic.php?f=181&t=7012
ayad [ 12 окт 2014, 10:29 ]
Please could you send that bios file to me , and I have read topic at https://vlab.su/viewtopic.php?f=181&t=7012 using google translate but I could not understand , so could you make that steps More clearly and precisely , and thank so much........
latitude [ 05 янв 2015, 19:25 ]
Hi guys, could someone send me files too, because I have same problem.
http://www.phpbb.com/
