Compute писал(а):
Voltage KBC (ENE KB9012) and chip bios correct? Firmware right? If so then KBC (ENE KB9012) died
It might be and i changed it also.nothing good
MSF113 писал(а):
kandyan
Check
LID_SW# - must be high
ON/OFF - triggered by power switch
PBTN_OUT# - triggered by power switch
PCH_RSMRST# - must be high
KB9012 has internal firmware (EC firmware). Try to reflash it (you need the special programmer to do this).
I changed KB9012 and reprogrammed it with "Maxim" s KB9012 programmer.
http://notebook1.ru/forma1/viewtopic.php?p=534436Now all other signals are ok but PCH_RSMRST# doesn't show anything high. I suspect South bridge is the problem is this case according to the symptoms. Shall I reball it or is there anything to check before reballing it?
