V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES https://vlab.su/viewtopic.php?f=59&t=24737 |
kandyan [ 23 сен 2014, 22:24 ] | |
Заголовок сообщения: | V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES |
Hi, I have got Acer V3-571 laptop with following symptoms. 01. When I turned it on power LED lights up for 5 senconds and turned off. 02. +3.3v and +5v available and +3VL and VLP (VREG3 andVREG5) are also available. 03. When I turned on the laptop U21 and U22 FETs does not turned on and not produced +3VS and +5VS 04. "SUSP" signal not coming to the Q19 and Q25 which are triggering the gates of U21 and U22. 05. Then I checked Q27 for "SUSP" signal. Unfortunately "SUSP#" must be there to generate "SUSP" signal. 06. "SUSP#" generates from KBC (ENE KB9012). Therefore where to start to solve this problem. |
Compute [ 24 сен 2014, 00:37 ] | |
Заголовок сообщения: | Re: V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES |
Voltage KBC (ENE KB9012) and chip bios correct? Firmware right? If so then KBC (ENE KB9012) died |
MSF113 [ 24 сен 2014, 09:01 ] | |
kandyan Check LID_SW# - must be high ON/OFF - triggered by power switch PBTN_OUT# - triggered by power switch PCH_RSMRST# - must be high KB9012 has internal firmware (EC firmware). Try to reflash it (you need the special programmer to do this). |
kandyan [ 24 сен 2014, 11:57 ] | |
Compute писал(а): Voltage KBC (ENE KB9012) and chip bios correct? Firmware right? If so then KBC (ENE KB9012) died It might be and i changed it also.nothing good MSF113 писал(а): kandyan Check LID_SW# - must be high ON/OFF - triggered by power switch PBTN_OUT# - triggered by power switch PCH_RSMRST# - must be high KB9012 has internal firmware (EC firmware). Try to reflash it (you need the special programmer to do this). I changed KB9012 and reprogrammed it with "Maxim" s KB9012 programmer. http://notebook1.ru/forma1/viewtopic.php?p=534436 Now all other signals are ok but PCH_RSMRST# doesn't show anything high. I suspect South bridge is the problem is this case according to the symptoms. Shall I reball it or is there anything to check before reballing it? |
MSF113 [ 24 сен 2014, 12:10 ] | |
Check what PCH_RSMRST# has no short cut. Check +RTCVCC Check XTAL25 on Y2 generation present |
kandyan [ 24 сен 2014, 14:55 ] | |
MSF113 писал(а): Check what PCH_RSMRST# has no short cut. Check +RTCVCC Check XTAL25 on Y2 generation present I didn't find anything abnormal in PCH_RSMRST# and +RTCVCC is present +3V XTAL25 on Y2 is working when RTC battery is on the battery bay. (Checked it with oscilloscope) Now I really think that problem is on south bridge bcz in this model there is no heat sink for it. So there is a dry contact under the PCH. I will reball it and let you know the results. |
MSF113 [ 24 сен 2014, 14:58 ] | |
Do you reflash main BIOS? |
kandyan [ 24 сен 2014, 20:04 ] | |
MSF113 писал(а): Do you reflash main BIOS? Yes I did. Main,Win8 and EC. |
kandyan [ 12 окт 2014, 21:12 ] | |
Заголовок сообщения: | Re: V3-571 (LA-7912P) NO +3VS AND +5VS VOLTAGES [РЕШЕНО] |
Everything works well after i reballed the South bridge. Thanks everyone for the help. and also when Dell 3521 boot up without display and making beeps sounds its better to reball the south bridge as well. Bcz I have reballed 1 beep, 4 beeps and 8 beeps dell inspiron 3521 and problem was solved. |
