Текущее время: 03 июн 2024, 08:25
 Заголовок сообщения: Acer V5-572g (DA0ZQKMB8E0 Rev:E ZQK) Will not start, SHORTED!
СообщениеДобавлено: 02 дек 2016, 21:29
ok guys , i have some nasty laptop v5-572g here with dead motherboard
motherboard is shored, when charger is plugged in i get 2.2V instead of 19v
i have taken out resistor PR45 , measured resistance to ground and i got like 240-300ohm on one side. i wanted to test the voltage, but i was stupid and the pu9 controller burned. i have replaced it with the same model
returned pr45 resistor and again i had 2.2v in the board
i have measured on +3.3valw and +5valw mosfets and ive seen that the voltage gets up to 2.2v and then drops to 0 and every 2 seconds it would go up to 2.2v and then dropped.
my thoughts were that the integrated RAM memory 4gb is defect. i have removed coil PL13 but when i plugged in the charger i got full shorted and charger went out, i had to discharge him and return coil pl13 back, then i got 2.2v again.
i have removed pq48 and pq55 but same shit
does anyone have any clue what else to do? what to test, what to remove and test?
problem is that i had acer boards which were all connected via coils ( all power circuits) and i could simply remove coil and detect where the short is.
i do not know what to do here.
please help me couse i want to repair this motherboard and gain knowledge.
i have found this board schematics: http://elektrotanya.com/acer_aspire_v5_ ... nload.html
 Заголовок сообщения: Re: Acer V5-572g (DA0ZQKMB8E0 Rev:E ZQK) Will not start, SHORTED!
СообщениеДобавлено: 03 дек 2016, 09:51
try this:
1. when charger is plugged in and you got 2.2V instead of 19v, find(use your finger) the hot or warm component on the motherboard. if there is no hot or warm component do below:
2. by injecting a voltage(with external adapter, 3V 3A is enough, more Ampere may cause component got burnt) to VIN. by this way, please do this carefully, your finger may burnt a little.
لا إله إلا الله محمد رسول الله
СообщениеДобавлено: 03 дек 2016, 18:45
ok i have soldered external power supply and pq9 got epicly hot and chips around him. since this happens on almost every motherboard ( the chips at start heat up and the short is somewhere else ) i have removed pq9 and soldered wire on his output and put 3v 0.5A inside and got low heat at ram chips, i put 5V 1.7A max inside and the ram chips got heat up a little bit more.
so the soldered RAM is shorted? how can i fix this?
anyone*?
В этой теме нет новых непрочитанных сообщений. V5-572G (DA0ZQKMB8E0 Rev:E ZQK) Shorted Onboard RAM , NEED HELP, WILL DONATE $$
draganzile
05 дек 2016, 22:35
draganzile Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer v5-572g (DA0ZQKMB8E0 Rev.E Model: ZQK) Не включается от 19в но при 9в работает
coretek
3571
02 май 2018, 22:49
coretek Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. ACER V5-572PG-53338G50am m (DA0ZQKMB8E0 REV.E Model ZQK ) Нужны дампы BIOS
VAGner1976
19 авг 2015, 15:31
VAGner1976 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Куплю на разбор Quanta ZQK (DA0ZQKMB8E0)
в форуме Куплю | Buy
mike2520
26 май 2015, 23:51
mike2520 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer v5-572g (DA0ZQKMB8E0 rev:E) Питание USB
Yojiq
4354
16 апр 2018, 12:22
Aleko-141 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 48
