Цитата:
It have the kbc in short circuit, but replaced with a new one. (damaged by a problem with the flex cable)
One month later and have some news:
The lcd screen was also damaged and now with a new one, there is image. (hwinfo32 and other utils does not detect it, only intel gpu)
The problem now is that discrete gpu does not work.
The gpu is powering by a six phase circuit that feeds it with .9 volts.
The xtal near gpu Y8 (27 Mhz) has a god oscillation signal.
All other voltage on mothrboard seems correct, except for those 2 coils near to cpu. (pl12 and pl15) (both are .22uH)
Those coils seems to feed the internal graphical part in cpu, but if it is a little estrange.
If someone has some comments it will be welcome.
Thanks.
