--- IPDT64 - Revision: 4.1.8.40
--- IPDT64 - Start Time: 07.09.2023 21:45:04
CPU1
Genuine Intel CPU Test
Module Version: 1.0.25.64b.W
Start Time: Thu Sep 7 21:45:04 2023
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Thu Sep 7 21:45:04 2023
Total Time: in seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.27.64b.W
Start Time: Thu Sep 7 21:45:05 2023
Test Result - PASS
Expected: Intel(R) Core(TM)
Detected: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
Intel(R) Core(TM) processor detected..!!..
End Time: Thu Sep 7 21:45:05 2023
CPU1
Cache Test
Module Version: 1.0.23.64b.W
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 48
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 1280
- Detected L3 Cache Size --> 24576
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Module Version: 1.0.29.64b.W
Start Time: Thu Sep 7 21:45:06 2023
Test Result - PASS
DetectUtils64 DLL Version - 1.1.8
--- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is supported on this CPU..
..SSE4.2 is supported on this CPU..
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
End Time: Thu Sep 7 21:45:06 2023
CPU1
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Detected Memory Size is --> 16.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 bytes
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Test Passed!!!
End Time: Thu Sep 7 21:45:07 2023
Total Time: in seconds: 1
CPU1
Parallel_PrimeNum Test
Module Version: 1.0.0.12
Start Time: 07.09.2023 21:45:07
Test Result - PASS
Module GraphicsW.exe Completed - Pass
Module Math_PrimeNum.exe Completed - Pass
GraphicsW Module Test
Module Version: 1.0.9.64b.W
Start Time: Thu Sep 7 21:45:07 2023
GraphicsW Module Test: PASS
End Time: Thu Sep 7 21:45:53 2023
Total Time: in seconds: 46
Prime Number Generation Test
Module Version: 1.0.28.64b.W
AVX is supported in your OS
Max AVX supported = AVX512
Test Result - PASS
Operation Per Second: 379067
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Thu Sep 7 21:45:52 2023
Total Time: in seconds: 45
Parallel_PrimeNum
End Time: 07.09.2023 21:45:53
CPU1
Parallel_FP Test
Start Time: 07.09.2023 21:45:53
Test Result - PASS
Module AVX.exe Completed - Pass
Module Math_FP.exe Completed - Pass
Start Time: Thu Sep 7 21:45:54 2023
End Time: Thu Sep 7 21:46:39 2023
AVX Test
Module Version: 2.0.30.64b.W
Start Time: Thu Sep 7 21:45:53 2023
Test Result - PASS
--- CPU Features Detection ---
..AVX is supported by this CPU..
..AVX2 is supported by this CPU..
..AVX512BW is supported by this CPU..
..AVX512CD is supported by this CPU..
..AVX512DQ is supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is supported by this CPU..
..AVX512IFMA52 is supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is supported by this CPU..
..AVX512VL is supported by this CPU..
..AES is supported by this CPU..
..PCLMULQDQ is supported by this CPU..
..AVX is supported by this Operating System..
Most Advanced AVX Feature Detected.. AVX512
AVX512 Test Result --- PASS
AES Test Result --- PASS
PCLMULQDQ Test Result --- PASS
Floating Point Test
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.455
Error: 0
--- Floating Point Test Passed!!!---
Parallel_FP
End Time: 07.09.2023 21:46:40
CPU1
Parallel_Math Test
Start Time: 07.09.2023 21:46:40
Test Result - PASS
Module FMA3.exe Completed - Pass
Start Time: Thu Sep 7 21:46:40 2023
End Time: Thu Sep 7 21:47:25 2023
Test Result - PASS
Operation Per Second: 380314
Error: 0
FMA3 Test
Test Result - PASS
..FMA3 is supported by this CPU..
..FMA3 is supported by this Operating System..
FMA3 Test Result --- PASS
Parallel_Math
End Time: 07.09.2023 21:47:25
CPU1
Parallel_GPUStressW Test
Start Time: 07.09.2023 21:47:26
Test Result - PASS
Module GPUStressW.exe Completed - Pass
GPUStressW Module Test
Module Version: 1.0.21.64b.W
Start Time: Thu Sep 7 21:47:26 2023
GPUStressW Module Test: PASS
End Time: Thu Sep 7 21:47:56 2023
Total Time: in seconds: 30
Test Result - PASS
Operation Per Second: 378618
Error: 0
Floating Point Test
FMA3 supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 0.39
Error: 0
Parallel_GPUStressW
End Time: 07.09.2023 21:47:56
CPU1
DGEMM Stress Test
Module Version: 1.0.16.64b.W
Start Time: Thu Sep 7 21:47:57 2023
Test Result - PASS
DGEMM AVX512 Test Result --- PASS
End Time: Thu Sep 7 21:48:58 2023
Total Time: in seconds: 61
CPU1
Frequency Check
Module Version: 1.0.7.64b.W
Start Time: Thu Sep 7 21:48:58 2023
Test Result - PASS
Processor Name: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz
Expected Processor Frequency: 2.30
Measured Processor Frequency: 2.303439
End Time: Thu Sep 7 21:48:59 2023
System Information
Processor Information: Family 6 Model 8D Stepping 1
Number of Physical Cores: 8
Number of Logical Cores: 8
Operating System: Майкрософт Windows 11 Домашняя 64-разрядная
Graphics Information: Intel(R) UHD Graphics
--- IPDT64 - End Time: 07.09.2023 21:48:59
--- IPDT64 - Result: Pass
