2032BW hellp https://vlab.su/viewtopic.php?f=91&t=96630 |
bokin021 [ 18 ноя 2019, 15:13 ] | |
Заголовок сообщения: | 2032BW hellp |
I have problem with monitor without panel ,start backlight when i install flat cable on panel button blinking,but no picture no back light , like short some where ..After that I install different screen panel and start normal turn on ,I have check 5v drop down when I connect on panel cable ..What I can check more ? PS I from lab power supply connect 5V direct on pin of screen but no short about 0.16A.. |
bokin021 [ 18 ноя 2019, 21:54 ] | |
Заголовок сообщения: | Re: 2032BW hellp |
Please can some one can help me ? |
Danila. [ 19 ноя 2019, 02:22 ] | |
did you check power board capacitors ? |
bokin021 [ 19 ноя 2019, 08:07 ] | |
Yes i did everything is ok,when i put second one panel normal turn on.. |
bokin021 [ 19 ноя 2019, 13:32 ] | |
I think that is wrong(CT1102) ,when I put up 3 leg no short anymore ,but also only white screen no picture ,maybe can some one tell me i m write or not ?I left datasheet.. |
bokin021 [ 21 ноя 2019, 11:00 ] | |
I have short in this place ,i removed and i put power supply 3V ,nothing is hot also, I add Amper more then 5 ,showing short but i cant find out ..Very strange problem.. |
bokin021 [ 21 ноя 2019, 22:09 ] | |
Please can someone help? |
Danila. [ 26 ноя 2019, 13:14 ] | |
if you have short - you should find there is. it may be one from ceramic capacitors.. |
bokin021 [ 27 ноя 2019, 15:13 ] | |
it is not there i have check |
mia [ 27 ноя 2019, 15:59 ] | |
IC3 by Q7 produce from input voltage on pin3 output voltage on C71. Look schematic - line from pin3 IC3 connected to many other components. Check it... |
