Текущее время: 20 апр 2024, 13:56
MSF113
Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing Добавлено: 18 окт 2014, 10:22 |
6 Caps Lock/Num Lock BIOS BIOS authentication failure
abuholm
Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing Добавлено: 18 окт 2014, 12:50 |
Зарегистрирован: 17 мар 2013, 15:22 Наличности на руках: 30.00
Сообщения: 198 Откуда: Ghana
MSF113 писал(а): 6 Caps Lock/Num Lock BIOS BIOS authentication failure Thanks for the reply but in this case it is the charging Indicator (orange led) that is blinking..
MSF113
Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing Добавлено: 18 окт 2014, 13:06 |
I don't see what charging LED blinking, sorry. charging LED blinking - problem with Power.
abuholm
Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing Добавлено: 18 окт 2014, 19:55 |
MSF113 писал(а): I don't see what charging LED blinking, sorry. charging LED blinking - problem with Power. I totally agree with you that it is a power issue because I just realized that there is no voltage on coil L29 [+VCCP] and L26 [+VCC_CORE], but everything was okay before the re-balling.All components around the South-bridge are okay. I will like to know if there are some signals I can check to verify whether the problem is from South-bridge or elsewhere.
