Текущее время: 27 сен 2024, 18:20
indirectdc@yahoo.ca
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 28 апр 2021, 01:44 |
Зарегистрирован: 27 апр 2021, 09:11 Наличности на руках: 77.06
Сообщения: 19 Откуда: Vancouver
suhar777777 писал(а): Enter a mods directory: cd /home/mods/rx590 5: AMD RX6900/RX6800/RX5700/RX5600/RX5500 series and after Support AMD's RX6900/RX6800/RX5700/RX5600/RX5500 or newer card. Does this mean I can use MATS/MODS for AMD card testing, or should I use Tserver/dmgg? Have 3 RX 5700s with different degrees but similar issues. One, shows errors after 15+ hours in mining and locks up/freezes the system/stalls driver. Second one shows it in 2-4 hours. Third, sometimes shows under Windows desktop, and whole screen turns green. Tried underclocking the memory on third from 1750 to 1250MHz and it at least mines for a bit. I can get the first to crash much faster if VRAM is set to 1900MHz. MATS/MODS or Tserver? Which version of Tserver? Thank you.
indirectdc@yahoo.ca
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 28 апр 2021, 07:02 |
Erminb писал(а): You can't use mats/mods for AMD cards. I'm not sure you can use successfully dmgg too on new generation cards. Tserver should do the job. Ok, only reason is because suhar777777's post indicated the newer version did. I guess not. Since I don't understand Russian I have to rely on translations and some english posts. The Tserver files are that big? In the range of tens of gigabytes? 16GB? Thanks for understanding.
indirectdc@yahoo.ca
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 06:44 |
Why can't I download Tserver from this link? https://drive.google.com/drive/folders/ ... mHDA1rztAbIt fails and says the drive is full. I first tried it few times on the USB drive that's a bootable Archlinux drive. It says 28GB is free so I figured it would work. Then I thought maybe I needed more space on my SSD since it had 14GB left. Then I tried to download from a system that has 28GB left, and still failed. Edit: Also getting Network failures time to time.
Gas_man
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 07:24 |
Зарегистрирован: 31 янв 2019, 21:09 Наличности на руках: 390.39
Сообщения: 305 Откуда: Чебоксары
indirectdc@yahoo.ca писал(а): Why can't I download Tserver from this link? Вы не читали инструкцию как распаковываются образы. Образы распаковываются через DiskGenius viewtopic.php?p=861154#p861154
indirectdc@yahoo.ca
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 07:43 |
Gas_man писал(а): Вы не читали инструкцию как распаковываются образы. Образы распаковываются через DiskGenius I'm not at that point yet. I cannot download the files.
Alex65
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 08:17 |
Зарегистрирован: 21 авг 2012, 23:42 Наличности на руках: 362.59
Сообщения: 303 Откуда: Брянская обл.
indirectdc@yahoo.ca писал(а): I cannot download the files. Archive 18GB, deployed 70GB. It downloads normally, look for the problem yourself. Gas_man писал(а): Образы распаковываются через DiskGenius этот образ в другом формате и распаковывается HDClone (есть в архиве).
_________________ Электроника — наука о контактах.
Markot77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 10:33 |
Зарегистрирован: 13 май 2014, 12:09 Наличности на руках: 23.09
Сообщения: 18 Откуда: Московская область
indirectdc@yahoo.ca писал(а): I'm not at that point yet. I cannot download the files. У меня тоже были проблемы со скачиванием оттуда, в итоге скачал с его Telegram канала https://t.me/vik_on_shem/681Crimfell писал(а): Скачал. Позже в этой папке появятся все файлы. Архив разбит на части, по 2 гигабайта, ограничения в облаке. Нужно скачать все части, сложить в одну папку и распаковать при помощи 7zip. Ссылка будет активна в течении месяца, далее я удалю все, так как слишком много места занимает в облаке. В общем делайте зеркала. https://cloud.mail.ru/public/WEkP/FsmED234gЕсть у меня халявный терабайт в облаке, перезалил к себе вместе с инструкциями от Gas_man, будет лежать пока будет актуально. https://cloud.mail.ru/public/EhiW/fQmwgSdR2
YunicheK
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 29 апр 2021, 15:42 |
Зарегистрирован: 07 апр 2018, 15:32 Наличности на руках: 386.32
sa_82 писал(а): капец скорость маленькая((( неделю качать Скажите спасибо, что это вообще где-то скачать можно, причем бесплатно))) Кстати тоже есть халявный терабайт, разместил у себя в облаке на длительное хранение. https://cloud.mail.ru/public/6R6H/Yz4wNSx9m
Crimfell
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 апр 2021, 00:46 |
Зарегистрирован: 08 ноя 2015, 21:28 Наличности на руках: 69.41
Сообщения: 327 Откуда: Армянск
юрий62 писал(а): нет 15 сообщений не могу смотреть вложения Зачем старая версия, скачайте новую. ---------- Добавлено спустя 45 секунд: ---------- Markot77 писал(а): 7zip соответственно тоже начал сыпать ошибки CRC при распаковке *.pmf Не знаю, я архив у себя проверял, все отлично. ---------- Добавлено спустя 2 минуты 14 секунд: ---------- sa_82 писал(а): капец скорость маленькая((( неделю качать
Это Вы ещё с байду без према не качали. А если серьезно, то в Китае, за этот диск, просили 3000 долларов. Мы же отдаем его совершенно бесплатно. И да, со скоростью у майл облака нет проблем, у меня под 11 мегабайт в сек. Так что ищите проблемы на вашей стороне.
Markot77
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 апр 2021, 01:55 |
Crimfell писал(а): Не знаю, я архив у себя проверял, все отлично. Дык я и не говорю, что изначальный архив плохой ) у меня тоже все отлично в итоге распаковалось. Я говорю, что сомнительно скачивать одним большим файлом (архивом 55ГБ, где содержаться все 29 частей) с облака, есть вероятность получить битый архив. Crimfell писал(а): И да, со скоростью у майл облака нет проблем Подтверждаю, у меня тоже с майла на всю качает.
sa_82
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 апр 2021, 07:02 |
Сообщения: 2 Откуда: уфа
YunicheK писал(а): Скажите спасибо, что это вообще где-то скачать можно, причем бесплатно))) Кстати тоже есть халявный терабайт, разместил у себя в облаке на длительное хранение. https://cloud.mail.ru/public/6R6H/Yz4wNSx9mизвеняюсь ))) конечно спасибо ... но а чего такая скорость то маленькая в целом ? ограничение или еще чего ? и докачать нельзя при сбое ((( ---------- Добавлено спустя 3 часа 25 минут 2 секунды: ---------- как скачаю торрент останусь на раздаче...
Crimfell
Заголовок сообщения: Re: need some help for ati cards with memory errors for making script Добавлено: 30 апр 2021, 17:12 |
roman2580 писал(а): Всем привет. Может кому понадобится торрент. Я пока буду на раздаче. Присоединяйтесь Я специально ушёл от торрента, а то вечно нет сидеров. Уже несколько зеркал есть, я думаю торрент не актуален. Хотя, может кому и пригодиться. P.s. Надо выполнить обещание и научить ув. товарища wohenben09 пользоваться софтом.
