AndreyVl96 писал(а):
engineering dump try viewtopic.php?p=492200#p492200 and carefully check the board model ---------- Added after 2 minutes 33 seconds: ---------- you may not be identifying correctly the name of your board or perhaps someone re-pasted the sticker with the name , you can search for the name in the original dump if you saved it
no change:(
still boot without delay but fans are high speed
sticker is removed but motherboard model is n550jv
