hello, I decided to make a reflow on the gpu and on the memories and the artifacts on the windows screen are gone, in heaven benchamark I also didn't notice any artifacts, but when opening Msi Kombustor it still detects several artifacts, I believe it really is a case of reballing.
Posted after 3 hours 51 minute 30 seconds:GA-8i915 писал(а):
if amd, then try compare heat video memory, clip video memory and gpu, off vtt for video every separately chips. But the fastest heat test for gpu.
unfortunately I don't have a thermal imager,
I left heaven running for a few hours and the card was apparently working normally, so I went to play The Division 2, and after about 15 minutes the artifacts came back.
if i put a heatsink just noble to the GPU, can i notice any difference in temperature in the memory modules?
